996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 14
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
mike123
PostPosted: Fri May 19, 2017 3:59 pm    Post subject: Help needed Reply with quote
Afternoon guys
I need to remove the headlamps and it appears that one of the hex bolts that releases the headlamp is snapped.
Any ideas on how I can get around this?
Mike
997.1 C2S (Hartech Engine)
Shanghai
PostPosted: Fri May 19, 2017 6:14 pm    Post subject: Reply with quote
Are you sure its snapped as sometimes they angle away and the tool wont connect.
The tool isnt worn or cracked is it ?
If not its possible its been rounded off a bit .. a selection of 1/4 inch sockets on an extension would be my first attempt , failing that you could pull the arch linner out and see what access you have .
Not something ive come accross before im afraid .. i usually manage to jam something on it in the end .
At an Indy these days !
mike123
PostPosted: Sun May 21, 2017 7:39 pm    Post subject: Reply with quote
It had completely snapped off.
I managed to get the smallest of bites from a drill bit and the light came out.
Next question...... does anybody have idiot proof instructions to remove a 997 bumper?
Mike
Dexterich
PostPosted: Sun May 21, 2017 8:02 pm    Post subject: Reply with quote
Hi Mike, I had exactly the same issue, managed to get the light out by brute force really from the front (using some plastic interiror tools to lever the headlight) - must have been really tricky to get a drill bit in there Surprised.
I can't remember where I got mine but if you google you will find plenty of instructions for PU removal, it's not difficult but there are quite a few steps - I always take loads of photos as I go!
C2S, Black, Tiptronic
