997 : 2004- 74
996 : 1997-2005 42
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Pearcy
PostPosted: Wed May 17, 2017 11:03 pm    Post subject: TC button / TC off button MY98 MY99 Reply with quote
I am aware that all 97/98 C2's were cable throttle and that majority had TC. I believe these had a 'TC off' button on the dash?
IRO MY99 C2's, specifically looking at one with 030/220/222 it has a 'TC' button on the dash. Does this mean it's a cable throttle car? - this particular one was manufactured early very early Jan 1999
Thanks!
Griffter
PostPosted: Thu May 18, 2017 5:27 am    Post subject: Reply with quote
I can't answer your question, but you can spot a cable throttle car from a photo of the engine bay if that's any help. The throttle bodies are different (fbw has a plug on the side or something - google will clarify).
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu May 18, 2017 6:12 am    Post subject: Reply with quote
As mentioned, the easiest way to spot a cable throttle car is to open the boot and look for the cable. As you look at the throttle body it will be on the right hand side. I believe that the C2 changed from cable to e-gas at some point in MY99 so if yours is an early one it might be cable throttle. It looks like this:
GT4
Nordschleife
Nordschleife
PostPosted: Thu May 18, 2017 8:36 am    Post subject: Reply with quote
As above for visual confirmation, but regarding the TC button, where fitted, it does mean mechanical cable, eGas models are PSM.
wasz
Watkins Glen
1999 Porsche 996 Carrera 2
PostPosted: Thu May 18, 2017 8:57 am    Post subject: Reply with quote
TC on cable throttle was an option, my MY99 doesn't have it.
TBH the TC is so basic its not worth looking for. AFAIK it just retards the ignition to cut the power when slip detected, which you can do with your right foot.
Personally I've never missed it, having had similar basic TC in other cars.
PSM on later cars and c4 would be worth having, as its the proper individual brake setup of modern cars, but some say those cars are different to drive with increased electronic interference, so you have a trade off.
I do wish I had cruise control though, which is an easy mod on a electronic throttle car, but on a cable throttle you need a cable actuator wiring in.
Pearcy
PostPosted: Thu May 18, 2017 9:06 am    Post subject: Reply with quote
Thanks, but forgot to check when I viewed the car! hence asking on here re TC button on dash
Pearcy
PostPosted: Thu May 18, 2017 9:08 am    Post subject: Reply with quote
Great! - that's the info I was looking for, thanks for confirming that Smile
Pearcy
PostPosted: Thu May 18, 2017 9:11 am    Post subject: Reply with quote
Not looking for TC, but am specifically looking for a cable throttle C2 coupe, pref with M030/220.
Not generally a fan of 'egas' type throttles - have that on the daily driver, looking for something purer on the 'weekend toy' but I appreciate that we're all looking for different things depending on personal preference/opinion Smile
GT4
Nordschleife
Nordschleife
PostPosted: Thu May 18, 2017 10:41 am    Post subject: Reply with quote
As indicated ("where fitted"), yes it was an (expensive) option.
I believe the OP was simply looking for a way of determining (confirming) a mechanical cable model.
Although optional TC was not fitted to all non-eGas, IF it is fitted (ie TC button on dash) that does confirm the car is non-eGas.
As MC mentioned, best bet (in person) is the visible cable!
If perusing Autotrader ads (for example), the TC button is more likely to be posted as a general dash shot than a close up of the throttle body! (although it obviously only confirms a very small proportion of perfectly valid non-eGas)
demon
PostPosted: Thu May 18, 2017 12:09 pm    Post subject: Reply with quote
I have a '98 M030/220 car with TC
- it also has >200k mileage... because its good to drive and has been driven every day i.e. don't let high mileage put you off if you find the spec you want
FYI - TC is a performance enhancement, not a safety aid (like PSM) i.e. it is intended to allow you to apply a heavy right foot with reduced finesse yet more consistent results when accelerating/launching the car hard..... so you might find you rather like finding the little TC button : )
GT4
Nordschleife
Nordschleife
PostPosted: Thu May 18, 2017 4:57 pm    Post subject: Reply with quote
Saves tyres
