997 : 2004- 66
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Classic : 1950-1965 1
Boxster : 1997- 15
Cayenne : 2003- 9
912-914-924-928-944-968 4
gbspeed
PostPosted: Mon May 15, 2017 7:05 pm    Post subject: Pentosin leak from main reservoir Reply with quote
The engine is out of my 997 Turbo Gen 1 for some major service work and to source a pentosin leak.
Well its been sourced and its one of those annoying/costly ones.
Its not the operating cylinder (notice the well sealed red clip)
Its coming from the main reservoir that connects the two lines for the low pressure return lines from the power steering rack and slave
See in picture the annoying little red clips (known as festo fittings I believe)
The specialist has been informed by Porsche that the red connectors are not supplied with the replacement pipes but are in fact part of the reservoir unit (circa £500).
They are trying to source the connectors direct from the manufacture but I am not holding my breath (no insult to the specialist just the pessimist in me I guess ). Sad
So does anyone have any experience with this or maybe a bright idea worth pursuing before I bend over to Porsche.
and a little engine porn to brighten the post
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Tue May 16, 2017 6:08 pm    Post subject: Reply with quote
Sorry, can't help but the Mezger looks lovely!
Coolant lines all good into the block?
reisskhan
PostPosted: Wed May 17, 2017 1:28 am    Post subject: Reply with quote
buddy search for some hydraulic pressing place near or call some one like and sure they can fix it or guide you in the right direction
should hopefully be a cheap fix
