Supercharged 996 on Ebay
Not to mention the Hartech rebuild 1000 miles ago :thumbs:
Looked at this a few times now, has to be a decent buy at that money if all is good. Do like the idea, the SC kit is only a few K less than what the car is advertised at
Looks a bit rough around the edges - doesn't look like it's had any recent use (as he says) judging by the leaves in the engine bay and the rust/oxidisation on various parts - be good to see underneath as I suspect it will be quite rusty.
That spoiler looks horrible - an attempt to accommodate the supercharger and air filter by the look of things
Suspect that will cost a lot to bring up to scratch - could be an interesting project for someone - but at under £10k though I'd say.
9 years ago. It must have barely been run in, in all that time.
The ad's not clear whether Hartech rebuilt the engine - just that they replaced it. The cat-d rating and the tiptronic probably lower its desirability a notch or two.
MOT history is pretty appalling. Worth a read.
Some numpty has put the steering wheel on upside down :joker: clearly blinded by the suicide savannah interior :grin:
Good big grin project car as a keeper, but not if your looking to make any money on it long term. funny a few of the guys around my way have been chatting about that very car today and its potential as a fun project car for not bad money. :thumb:
Only 1500 miles since 2008. That's either wrong or a soon as you drive the list of jobs to be done will grow.
Ooh that looks like lots of Bhp per £... I imagine it would be a fun.. shame it's a tip :dont know:
Needs discs all round, has suspension of god knows what, needs all sorts of bushes, has an oil leak. List goes on.
Vehicle makePORSCHE Vehicle model911 Date first used31 December 1998 Fuel typePetrol ColourBlue
MOT history of this vehicle
Test date22 April 2017 Expiry date21 April 2018 Test ResultPass Odometer reading118,540 miles MOT test number7702 7351 5607 Advisory notice item(s)
Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
engine light on
both front brake hoses been repaired and painted
Test date15 April 2017 Test ResultFail Odometer reading118,529 miles MOT test number5290 4761 4219 Reason(s) for failure
Nearside Side repeater not working (1.4.A.2c)
Nearside Front Brake hose ferrule excessively corroded (3.6.B.4e)
Offside Front Brake hose ferrule excessively corroded (3.6.B.4e)
Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Test date20 October 2015 Expiry date19 October 2016 Test ResultPass Odometer reading118,358 miles MOT test number9631 0801 4958 Advisory notice item(s)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
oil leak
Nearside Front Anti-roll bar linkage ball joint dust cover deteriorated, but preventing the ingress of dirt (2.4.G.2)
Nearside Rear Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
Rear brake disc worn, pitted or scored, but not seriously weakened both (3.5.1i)
Brake pipe slightly corroded front to rear (3.6.B.2c)
Test date20 October 2015 Test ResultFail Odometer reading118,358 miles MOT test number7790 2965 6700 Reason(s) for failure
oil leak
Test date18 March 2014 Expiry date17 March 2015 Test ResultPass Odometer reading118,317 miles MOT test number6778 0707 4082 Advisory notice item(s)
boot open light on
battery light on intermittent
Oil leak
slight pitting brake discs
slight play rear antiroll bar links
Test date8 March 2014 Test ResultFail Odometer reading118,307 miles MOT test number6654 9706 4041 Reason(s) for failure
Main beam 'tell-tale' not working (1.7.4c)
Nearside Headlamp not working on dipped beam (1.7.5a)
Nearside Front Headlamp not working on main beam (1.7.5a)
Offside Front Headlamp not working on dipped beam (1.7.5a)
Offside Front Headlamp not working on main beam (1.7.5a)
Rear fog lamp not working (1.3.2b)
Rear fog lamp tell tale not working (1.3.1b)
Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Front Windscreen washer provides insufficient washer liquid (8.2.3)
Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
Bootlid cannot be secured in the closed position (6.4.1)
boot open light on
Oil leak
Test date4 January 2013 Expiry date3 January 2014 Test ResultPass Odometer reading118,283 miles MOT test number2083 9440 3063 Advisory notice item(s)
Offside Rear Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
slight play in drivers door hinge
light switch affects heater
nearside rear tyre inner wall starting to split
Test date2 January 2013 Test ResultFail Odometer reading118,283 miles MOT test number2690 7260 3083 Reason(s) for failure
Horn control insecure (1.6.1)
Offside Headlamp not working on dipped beam (1.7.5a)
Nearside Rear Tyre not fitted in accordance with side wall instructions (4.1.D.1f)
Offside Rear Tyre not fitted in accordance with side wall instructions (4.1.D.1f)
Service brake: service brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
Test date2 March 2011 Expiry date1 March 2012 Test ResultPass Odometer reading118,164 miles MOT test number6264 3126 1050 Advisory notice item(s)
Offside Rear Rear wheel bearing has slight play (2.6.2)
rear tyres getting low
Test date10 November 2008 Expiry date9 November 2009 Test ResultPass Odometer reading117,050 miles MOT test number8008 1501 8386
Test date9 August 2007 Expiry date8 August 2008 Test ResultPass Odometer reading115,419 miles MOT test number7947 4162 7272
Test date7 August 2007 Test ResultFail Odometer reading115,419 miles MOT test number8015 4931 7279 Reason(s) for failure
Brakes imbalanced across an axle (3.7.B.5b)
Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
brake warning light on
non standard suspension fitted
front to rear undertrays fitted
front brake pads and discs worn close to limit
long handbrake travel
Test date19 August 2006 Expiry date18 August 2007 Test ResultPass Odometer reading113,988 miles MOT test number3112 8123 6427 Advisory notice item(s)
Front brake disc slightly scored (3.5.1h)
FECK thats a long old list, seems the wheel nuts are ok though :grin: :thumb:
suddenly it an 8k car :eek: and cherished well his poor wife :floor: :floor:
Ouch, that will be expensive huh!
124,597
1,441,970
49,033
drthein
