996 : 1997-2005 49
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 3
pietrzj
PostPosted: Sat May 13, 2017 8:50 pm    Post subject: Seatbelt light - does it work? - Solved Reply with quote
All, i wondered whether the seatbelt warning light in the clock gets illuminated during the bulb check when you turn the key two clicks.
Mine never illuminates. Is this normal? If you drive without the belt plugged in what happens? Is the light on and does a buzzersound? Not tried this yet, but I am confused why at least the bulb never lights. Oh and i have checked the bulb - its good.
Jan
PostPosted: Sat May 13, 2017 10:14 pm    Post subject: Reply with quote
Might be the sensor in the seat Dont know The seatbelt light should illuminate on the warning light ignition setting and only goes out when you clip the seat belt in the fastener.
There's no buzzer
pietrzj
PostPosted: Sun May 14, 2017 4:37 pm    Post subject: Reply with quote
Thanks, got it sorted. As you suggested, the connector under the seat was disconnected.
