997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Dammit
PostPosted: Thu Sep 19, 2019 7:51 pm    Post subject: Reply with quote
Whichever wheel I choose will be sent to BG Developments along with a hub/upright so that they can work out what looks reasonable from a rotor diameter.
I've gone backward and forward on the PCCB thing for ages now and I think I've finally decided to save the money that I'd spend on the discs and get lightweight callipers (six piston front/four piston rear AP Radi-cal) instead, along with fully floating rotors on alloy bells.
Mark - I take your point, but I'd like there to be some clue to the degree to which the car has been modified. It's going to look 100% stock bar the ride height, and if I stuck with the five spokes, the enormous brake rotors visible through the wheels.
I think either an LM or an E88 would be a nice hint that there is ~GT3 power hanging behind the rear wheels.
Jamesx19
PostPosted: Thu Sep 19, 2019 9:10 pm    Post subject: Reply with quote
E88 magnesium? If lighter than LM, then E88. Otherwise look very similar.
Bottom line is, as long as the centres are Weiss gold or similar, either.
1998 C2 Manual + The Full Hartech.
crash7
PostPosted: Sat Sep 21, 2019 8:40 am    Post subject: Reply with quote
E88 are not magnesium.
E28 are magnesium, I have a set, however they were prone to cracking on cup cars, as such the E28 was replaced with the E29, which looks almost identical, however they are made from alloy, which negated the cracking issue.
The issue with the E29 was that they were heavier than the E28, quite significantly heavier.
In an attempt to the lower the weight BBS made the E88, which again is almost identical to the E29, also alloy, but the spokes are scalloped to reduce weight.
All of the above are 3 piece motorsport wheels which come with lightweight barrels and lips.
BBS LM are a road wheel, again alloy, but a different shape centre to the E28/29/88, they are generally a 2 piece wheel and are much heavier but more robust.
Jamesx19
PostPosted: Sat Sep 21, 2019 7:09 pm    Post subject: Reply with quote
Thoughts on light weight wheels, based on experience with Fuchs.
The fronts were around 4 kgs lighter and rears approx 5kgs. Significant.
But overall wheel weight reduction including tyres is not so headline grabbing. Fronts 21 kg down to 17kg = -19%. Rears 24kg down to 19kg = - 21%. Also the weight reduction is at the centre of the wheel tyre combination so moment of inertia isn't massively affected.
None the less, the car feels tangibly more delicate. But this is through back to back comparison, it's not a night and day improvement irrespective of what some claim.
This would lead me to comment that within reasonable bounds, go for the wheels that you like the best, not necessarily die in a ditch to get the lighter ones.
Dammit
PostPosted: Sat Sep 21, 2019 7:53 pm    Post subject: Reply with quote
I think I'll go for LM's, Gert can get them in the correct light gold colour, then I can see whether gaining 5cm on the rotor diameter and going to 6 piston front and 4 piston rear can be offset by alloy bells and AP callipers.
That last part has been one I've agonised over as Porsche and Brembo are so closely associated - until I saw this years Le Mans car running AP callipers and steel discs, at which point I thought "ok then".
With the engine, gearbox and other stuff that Mistercorn and I have been working on the car is going to be evolving in a new direction - which I'm very happy with as these things should be a vessel for creativity rather than a straightjacket that prevents it.
Although with that said the overall aesthetic is still critically important - I'm considering what decals should go on the callipers for e.g. as the Radi-Cal ones are gopping.
coullstar
PostPosted: Sat Sep 21, 2019 10:47 pm    Post subject: Reply with quote
Even AP were not affiliated with factory cars I'd say go for it as they have so much kudos and are function + form. I'd much rather run them.
Dammit
PostPosted: Sun Sep 22, 2019 9:47 am    Post subject: Reply with quote
AP are owned by Brembo, also.
Dammit
PostPosted: Tue Sep 24, 2019 7:32 pm    Post subject: Reply with quote
Decision made, sorry Mark.
Marky911
PostPosted: Tue Sep 24, 2019 8:32 pm    Post subject: Reply with quote
Haha, don’t be daft. Thumb
Gorgeous wheels. It’s all personal preference and I’m sure they’ll look ace.
As you know I’ve currently got my gunmetal grey GT3 wheels for sale as I’ve gone back to silver ones. Even though it’s something I planned before even collecting the car, I now think I prefer the grey ones. It’s funny what we get used to and how our brains work. eh!
Are they made to order then Neil? If so when’s the ETA?
I’m guessing they’ll not see much use until next year now. Do they lacquer the rims or leave them bare so they can be polished up whenever necessary?
Dammit
PostPosted: Tue Sep 24, 2019 8:43 pm    Post subject: Reply with quote
They’re made to order, should be delivered some time in the New Year, and it’ll be Spring before they are out on the car.
8.5” front and 11” rear- wondering about moving my current tyres over, what do people think? Current wheels are 8” front and 10” rear with 225/40 front and 285/35 rear (IIRC).
Not sure about the lip- it may be a polishing hell about to happen.
Marky911
PostPosted: Tue Sep 24, 2019 8:54 pm    Post subject: Reply with quote
Your current tyres will work but aren’t the equivalent Porsche recommended sizes of 235/295.
They’ll look a tad more stretched.
Yes, I’ve tried both options on polished lips. You can’t win.
Lacquered keeps them bright but you’ll get a stonechip then water will get in and you’ll get a white spiders web.
Bare means no corrosion but you cannot easily keep them polished to that “as new” brightness. It’s a regular job trying to keep them like a mirror.
jezgreen911
PostPosted: Tue Sep 24, 2019 9:00 pm    Post subject: Reply with quote
Great wheel choice Thumb
Would like a set of LM's or E28/88's for mine one day Cool
2003 996 C2
Dammit
Thanks for the table- interesting.
If anyone wants perfect condition 5 spokes let me know and we can sort it out when my LM’s arrive.
coullstar
PostPosted: Tue Sep 24, 2019 10:25 pm    Post subject: Reply with quote
Good choice,when I had my image rims they were bare alloy, TBH they were PITA. I think LM's are lacquered from factory.
I was told to use Gtechnic wheel sealent but sold the wheels before using it.
Dammit
PostPosted: Thu Sep 26, 2019 7:43 am    Post subject: Reply with quote
The rears are 11” ET56- does anyone know (Henry?) if I’ll have to roll the arches?
Marky911
PostPosted: Thu Sep 26, 2019 8:02 am    Post subject: Reply with quote
Should be fine but that’s the most you’d want the wheel sitting out in the arch, especially with no aerokit to even the look out a bit.
Standard Mk2 GT3 are 11 inch with 65 offset. Yours are gonna sit 9mm further out but if your using 285 tyres instead of the “correct” 295 you’ll save 5mm in and 5mm out so you’ll be 4mm further out than factory GT3.
I’m sure my tyres don’t run within 4mm of my arch lips so there should be room.
Again though I’d just worry about the wheels looking to wide for the car if they’re gonna stick out. Should be ok though.
Edit. Just been out to the garage and I wouldn’t want the front lips of my wheels sticking out another 9mm. They may not catch but I think it’s just too far out to look right. nooo
Oh and if you did move upto 295s then it really would be close, clearance wise.
Henry will know though. Thumb
coullstar
PostPosted: Thu Sep 26, 2019 3:27 pm    Post subject: Reply with quote
Those will be pretty much flush with the arch but with 285's I think you will be fine.
Ive run 10in et38 on mine which stick a further 5mm out and they didn't rub at all however that was with 265/40 in tyres so slight stretch.
Dammit
PostPosted: Thu Sep 26, 2019 9:03 pm    Post subject: Reply with quote
Dammit
PostPosted: Sat Sep 28, 2019 8:43 am    Post subject: Reply with quote
coullstar
PostPosted: Sun Sep 29, 2019 9:06 pm    Post subject: Reply with quote
Can you cancel the LM's????
http://911uk.com/viewtopic.php?p=1503592#1503592
Goto page Previous  1, 2, 3 ... 42, 43, 44, 45  Next
Page 43 of 45
