997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
PostPosted: Thu Aug 08, 2019 10:29 pm    Post subject: Reply with quote
Once you head off East from Macon the fun really starts Driving
Dammit
PostPosted: Sun Aug 11, 2019 9:33 am    Post subject: Reply with quote
I want to put a usb power socket in the cubby behind the handbrake- if anyone can suggest a suitable source of switched power I’d be very grateful.
MJA911
2012 Porsche 991 Carrera
PostPosted: Sun Aug 11, 2019 11:45 am    Post subject: Reply with quote
You could use a piggy back fuse tap off the fuse that includes the existing 12v cig socket and run a suitable power line from the fuse box under carpets and up into centre console where you need it. Just did something similar to run switched power from a fuse to the roof up/down switch on the 986 dash.
991.1 C2, 986 Boxster S
Past pleasures: 997.1 GT3, 997.2 C4S Cab, 993 C2, 997.1 C2S, 996.1 C4
Dammit
PostPosted: Sun Aug 11, 2019 3:21 pm    Post subject: Reply with quote
I found that my cigarette lighter socket in the dash is switched with the ignition, so spliced into those wires. The new USB socket works, and I've now got an aux cable and power in the cubby.
However, the bluetooth transmitter that I was planning on using to enable Spotify to be used is a big disappointment - very quiet and the sound quality isn't great.
I think I'm back to stuffing a load of CD's in the passenger door pocket.
Dammit
PostPosted: Thu Aug 15, 2019 2:34 pm    Post subject: Reply with quote
MJA911
PostPosted: Thu Aug 15, 2019 3:11 pm    Post subject: Reply with quote
Looking great, not ridiculous at all Thumb
Dammit
PostPosted: Sat Aug 24, 2019 11:54 am    Post subject: Reply with quote
Opening the roof remotely using the key means that rather than opening fully (which it used to do) it opens to this point and then stops.
You can open it the rest of the way with the button in the cabin.
Why is this?
PostPosted: Sat Aug 24, 2019 12:03 pm    Post subject: Reply with quote
Sounds like you're getting a break in the signal from the key to the car. Whilst you do it, watch your key fob and check the red light is continually flashing whilst operating it.
Does it put the roof up fully when doing it the opposite way?
Dammit
PostPosted: Sat Aug 24, 2019 12:13 pm    Post subject: Reply with quote
Good question, I will find out.
Dammit
PostPosted: Sat Aug 24, 2019 12:21 pm    Post subject: Reply with quote
Mine sometimes does the exact same.
PostPosted: Sat Aug 24, 2019 7:45 pm    Post subject: Reply with quote
If it works on the button then i agree with Alex .. its an interference of the fob signal .. mobile phone , pylon .. later cars and the tracking fob can also do this .. big problem on the 991 in the early days .
It is also at the point that the rear side flaps should lower ( colour coded fabric covers each side ) .. i'm wondering if that has anything to do with it ..
The safety feature is if the flaps havent hit the micro switches at this point on the lowering cycle then it shuts down the operation to save any damage from happening .
Probably the fob losing the signal but a bit of a coincidence when its at this exact point in its operation .
Dammit
PostPosted: Sat Aug 24, 2019 9:31 pm    Post subject: Reply with quote
It's always this exact point that it happens, which is a bit of a coincidence.
PostPosted: Sun Aug 25, 2019 4:29 pm    Post subject: Reply with quote
Next time it does this then look at the flap in the image below .. is one side higher than the other indicating its sticking ?
A bit of spray lube on the sliders ( white plastic feet ) will often cure this .
 Filesize:  87.62 KB
 Viewed:  1397 Time(s)
Dammit
PostPosted: Sun Aug 25, 2019 4:57 pm    Post subject: Reply with quote
I shall have a look.
Got back from Morzine yesterday so thought I'd see if I could have taken the road bike with me:
And whip it apart:
Offered it up and I'd have to pull the cranks, which I didn't have time for:
So in conclusion, if I was prepared to break it down a little more, no problem - but not quite as simple as I'd hoped.
Dammit
PostPosted: Sun Aug 25, 2019 9:34 pm    Post subject: Reply with quote
Right - brief Morzine trip write-up, which was ~1,500 miles, 200 ml of oil, and more tanks of fuel than I want to think about.
First to Rambouillet to drop off the Mrs:
Then I went via the D996, D959, D928 (and some peage) to the dubious charms of the hotel Rhodos.
I picked up a Santa Cruz Megatower (the bicycle version of a racing monster truck):
And did a lot of this:
Which was great fun. Then I woke up to this:
Which was less than great, so a quick onesie shopping trip later:
And back out (things looked a little different):
Doesn't really come through here, but it was absolutely howling it down when I took this:
And then, being the mountains, it was glorious again:
Morzine is so handy for being able to pop into the town for lunch before jumping on the lift again:
Final day I rode with some friends:
And sadly my final day also saw a puncture that marked the end of my time riding, so I headed back to Rambouillet, picked up the Mrs and headed for the Chunnel:
The car was faultless, 10.8 litres/100Km with the roof up, 11.7 with the roof down, as at home using cruise control at 130km/h as it was charging down a D road at a speed I won't mention. I had a great time, and making it a small driving holiday either end of a riding holiday was a lot of fun.
PostPosted: Sun Aug 25, 2019 9:40 pm    Post subject: Reply with quote
thumbsup
I love driving these cars in France. So many good roads, so little traffic!
coullstar
PostPosted: Sun Aug 25, 2019 10:19 pm    Post subject: Reply with quote
Ace, very jealous. One for the road trip and two for the biking. Did you venture up to Avoriaz? Been skiing there a few times with the kids.
Dammit
PostPosted: Mon Aug 26, 2019 6:31 am    Post subject: Reply with quote
Yep, headed up to Super Morzine, then along to Avioraz, I’d probably do more on that side of the valley next time as Les Gets is really busy.
iOlly
PostPosted: Thu Aug 29, 2019 6:51 pm    Post subject: Reply with quote
Those roads look mega!!! Thanks for sharing!! Wish I could actually ride a bike without falling off spectacularly slowly Sad.
Goto page Previous  1, 2, 3 ... 40, 41, 42, 43, 44, 45  Next
Page 41 of 45
