997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
crash7
PostPosted: Fri Nov 30, 2018 10:05 am    Post subject: Reply with quote
Thumb Nice
Dammit
Watkins Glen
PostPosted: Sat Dec 01, 2018 4:55 pm    Post subject: Reply with quote
Dammit
Watkins Glen
PostPosted: Sat Dec 01, 2018 5:52 pm    Post subject: Reply with quote
First, get your box of parts, dump some tools in there, head to the garage with it:
It's not going to look like this soon:
The surround just pulls up:
Function First shifter is held on by this grub screw:
Where we run into the first problem, as these:
Don't have what we need. What's larger than 2mm, but smaller than 2.5mm? That's right, the 18th Century, AKA 3/32".
One quick trip to the hand tools section of my local Wickes later:
Bingo:
[/img]
Dammit
Watkins Glen
PostPosted: Sat Dec 01, 2018 5:59 pm    Post subject: Reply with quote
Now it's time for the Torx bolts that hold the centre console in - a mixture of T30 and T20:
The trim panels simply pop off, revealing the screws underneath:
This plate comes free when you've removed the bolt:
There's a particularly annoying screw under the coin holder, which caused me some headscratching until I located it:
Pull the connectors off the window switches and remove the ash-tray unit, there is another screw underneath:
Don't forget the essentials:
Dammit
Watkins Glen
PostPosted: Sat Dec 01, 2018 6:10 pm    Post subject: Reply with quote
The white screw-cover will not be on there when this car leaves the garage next:
Pop out the side-panel on the left of the handbrake and lift the console out of the way, underneath you'll find this:
This entire post brought to you by virtue of this little electric lantern:
The 997 GT3 shifter is definitely made of better materials than the others - note the very large metal bushings holding the mechanism into the cradle:
Still, it's coming out!
Push the locking covers up and twist to lock, freeing the cable ends:
They just pull up and out:
Look at that bushing:
Undo all four of the nuts that hold the shifter down - one pictured here, they're all 10mm:
And out:
New SSK, the green cradle, when locked in place, centres the shift lever:
Like this (note plastic bushings on this):
Put the cables back in, remove the green Plastic-of-Centring, row through the gears whilst making "brmmm brmmm" noises to check that you've got the cables back in the right place:
Carnage:
Dammit
Watkins Glen
PostPosted: Sat Dec 01, 2018 6:17 pm    Post subject: Reply with quote
I'm going to take it for a spin when the DVLA acknowledge the new plate, so leaving the console off until then, so time to tidy up:
This photograph just for Mark:
roboxm3
PostPosted: Sat Dec 01, 2018 6:26 pm    Post subject: Reply with quote
I don’t suppose you’ll be looking to sell that now redundant 997 GT3 shift mech will you?? Question
Dammit
Watkins Glen
PostPosted: Sat Dec 01, 2018 6:37 pm    Post subject: Reply with quote
I'm afraid you have been beaten to it. I've also got a short shaft (fnar) coming from Function First, which I may try if the SSK+longer shaft doesn't work for me, so may yet re-fit the GT3 mechanism with the short shaft - time will tell.
PostPosted: Sat Dec 01, 2018 8:34 pm    Post subject: Reply with quote
I looked at every single picture .. ive had god knows how many of these appart but i still enjoy seeing the work involved .. love the lantern btw Smile
Hidden screws are always fun to find !
Blue plate bung req .. i agree there .. that would annoy even me .
Im rather scared by what you have hanging over your pride and joy though .. whilst i only have a cheap bike .. that would worry me Surprised
Edit .. if you use the green tool then it will be aligned correctly and you can refit the consol .
Dammit
Watkins Glen
PostPosted: Sun Dec 02, 2018 9:46 am    Post subject: Reply with quote
I used the green tool to centre the lever, then clicked the cable ends in place so there was no slack, removed the green tool and selected all the gears- if this is enough to validate that I did it correctly then I’ll refit the console?
PostPosted: Sun Dec 02, 2018 4:59 pm    Post subject: Reply with quote
When i replace cables then i use the green tool to set them up and then refit the consol... its basically what its for .
You Dont have to use it but if you dont then just make sure you can select all gears smoothly.
Dammit
Watkins Glen
PostPosted: Sun Dec 02, 2018 5:12 pm    Post subject: Reply with quote
Bonza, in that case I'll get the console back on.
Marky911
Watkins Glen
PostPosted: Sun Dec 02, 2018 6:13 pm    Post subject: Reply with quote
Good work. I decided to take the plunge on an FF shifter last week but the Delrin knob is out of stock with the 996 6 speed pattern on it. frustrated
It wouldn't be going on until next year anyway. No rush.
PS Getting something down from that ceiling must be like playing a very expensive game of Kerplunk. Very Happy
PPS I forgot to comment on that serious piece of machining on the previous page. Wowzers! Some time has gone into that. Was that a custom one off or do the company do a batch? I shudder to think of the cost.
Dammit
Watkins Glen
PostPosted: Sun Dec 02, 2018 6:22 pm    Post subject: Reply with quote
The tappet chest is a test piece, seen here bolted into a head to test all the dimensions:
The verdict is that there are a couple of tiny things that need attention, but overall it's good to sign-off, which is handy as there's a virgin billet bolted to the deck of the 5-axis that made the test piece ready to fire into action on Monday once we've given them the revisions.
Once the new one is made then it'll go into an engine for some miles over winter, then we'll pull it back out again to check that it's happy in Spring.
If that's all fine then we'll consider the tappet chest problem solved (with the application of a couple of billets of aluminium and some cash).
Marky911
Watkins Glen
PostPosted: Sun Dec 02, 2018 9:29 pm    Post subject: Reply with quote
Proper commitment to the cause. Nice job.
Who's doing the machining then? Hartech or a sub contractors. Mazak 5th axis?
Dammit
Watkins Glen
PostPosted: Sun Dec 02, 2018 9:35 pm    Post subject: Reply with quote
Place called Specialist Engineering - they do a lot of stuff for F1 teams, so I reckon they are well qualified when it comes to making parts for Porsche road engines.
PostPosted: Sun Dec 02, 2018 9:49 pm    Post subject: Reply with quote
Buckaroo more like Grin
coullstar
PostPosted: Mon Dec 03, 2018 3:51 pm    Post subject: Reply with quote
Any use?
https://www.ebay.com/itm/Porsche-996-986-throttle-bodies-Jenvey-SF48-Taper-kit/143037532004?hash=item214db38764:g:3xoAAOSwt0dcBJY0:rk:39:pf:0
2000 Audi B5 RS4
Dammit
Watkins Glen
PostPosted: Fri Dec 07, 2018 9:49 am    Post subject: Reply with quote
Thanks for looking out for things - we're going a different route on the ITB's though.
In (todays!) news, my registration has transferred, so I can drive the car on the road again. And it's therefore pissing down here in SE London. And I have to put the centre console back in. But apart from those things, back on the road!
Dammit
Watkins Glen
PostPosted: Fri Dec 07, 2018 4:48 pm    Post subject: Reply with quote
Put the Hertz DCX 100.3's in today, frankly can't tell the difference between them and the old Nokia units, but we'll see what they're up to when powered by something made in the last couple of years, rather than 20 years ago (the Nokia amp was used in the 993 IIRC).
The 997 SSK, combined with the Function First shifter is really good - throw is nicely snappy, shift is accurate, knob is easily to hand and near the steering wheel.
Goto page Previous  1, 2, 3 ... 30, 31, 32, 33, 34  Next
Page 31 of 34
