997 : 2004- 74
996 : 1997-2005 45
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
New997buyer
Yas Marina
PostPosted: Wed Sep 20, 2017 5:15 am    Post subject: Reply with quote
£4K (+£650 loss on the old stuff) - holy macaroni!?! Surprised
On a recent long distance road trip before I left I got new pads all round and the geo done to factory spec. No way as comprehensive as what you've done but what a difference it makes. Especially when I had to scrub off speed before arriving at a single track stone bridge with a large Shogun filling the only space that was there. Or belting along on damp single track roads where 'off' equates to remote peat bog or cliff. So I can fully empathise with the feeling that comes from having confidence in your car. IMHO you can't put a price on that! thumbsup
“Forum signatures with quotes from famous people is a form of pretentiousness beyond compare.” Abraham Lincoln
997.1 turbo
Ex 996.2 turbo, 996.1 C2
bakerboy4s
PostPosted: Wed Sep 20, 2017 7:19 am    Post subject: Reply with quote
There are not many issues with CG and their services Thumb
tom_nieto
PostPosted: Wed Sep 20, 2017 8:16 am    Post subject: Reply with quote
CG really know their stuff. I was very impressed with their work on my C2S. Were you not tempted to have them set up the nearly new bilsteins that you bought first?
peterg1955
PostPosted: Wed Sep 20, 2017 8:36 am    Post subject: Reply with quote
Very true, when I was up there for a day and a half it was a pleasure watching Chris and Pete at work and seeing the thoroughness and attention to detail that they both work to.
I mentioned to Chris that the only criticism of both CG and 911v (where I got my car) was that they are 'expensive' - coincidentally Tom from 911v turned up to collect a 996GT3 that he'd asked Chris to go over - but having dealt with both I thought any extra cost was fully justified by the care and service which was provided.
2002 996 C2 black/black with aerokit and M030
Dammit
PostPosted: Wed Sep 20, 2017 8:48 am    Post subject: Reply with quote
That actually never crossed my mind - given the potential power upgrade coming with the 3.7 litre engine I thought that the stock B4's would be outside their design envelope, the geometry that Pete from CG put together for the car as-is has been specified with the higher power output in mind.
I do wish I'd not spent almost a grand on suspension that I then took off 5,000 later, but I didn't know nearly as much about these cars then as I do now - and I had no plans to rebuild the engine.
crash7
PostPosted: Wed Sep 20, 2017 9:23 am    Post subject: Reply with quote
Please tell me more about this!
Who is doing the build for you, what BHP do you expect?
Dammit
PostPosted: Wed Sep 20, 2017 11:47 am    Post subject: Reply with quote
More detail on the engine when it's a bit more defined- in the R&D phase at the moment.
GT3 brake ducts- I presume I want the 996.1 era GT3 parts?
crash7
PostPosted: Wed Sep 20, 2017 12:00 pm    Post subject: Reply with quote
Cool Thumb
No, go for 997 GT3 ducts front and rear and be sure to buy them from your OPC, they cost less than £5, while other outlets are charging significantly more.
If you need the part numbers shout
Dammit
PostPosted: Wed Sep 20, 2017 12:11 pm    Post subject: Reply with quote
If you had the part numbers that would be very useful?
crash7
PostPosted: Wed Sep 20, 2017 12:16 pm    Post subject: Reply with quote
They are handed so you will need one of each
997 GT3 Front Brake Ducts (997.341.483.92) & (997.341.484.92)
997 GT3 Rear Brake Ducts (997.331.487.92) & (997.331.488.92)
They are a very cheap mod
Shanghai
PostPosted: Wed Sep 20, 2017 6:17 pm    Post subject: Reply with quote
Dammit wrote:
Demort wrote:
Yes .. it looks like the A/C drain .. position should be just behind the n/s/f wheel and to the left of the tunnel .
That's exactly where it is - should it leak continuously for 8 hours?
Not really unless the engine was running ..
I would suggest squeezing that rubber part and it will open up , you may well have a bit of debris blocking it .. the alternative is to disconnect it from the heater box n/s/f and put an air line down it .
Perhaps next time its serviced or your in a garage for work then let them do it .
EDIT
If it was a problem though you would have wet carpets by now .
At an Indy these days !
thecarfixer
PostPosted: Wed Sep 20, 2017 6:34 pm    Post subject: Reply with quote
You'll need to trim a crescent shaped piece out of the 'blister' on the rear arch shield (you'll see when you fit the rear ducts) otherwise they'll rub. About 15mm at the centre of the blistered out section, tapered neatly does the job.
Dammit
PostPosted: Thu Sep 21, 2017 6:35 pm    Post subject: Reply with quote
They're ordered so I'll bear that in mind when they turn up - thanks both.
This arrived today:
The Porsche mounting bracket is coming with the brake ducts.
maldren
PostPosted: Fri Sep 22, 2017 7:22 am    Post subject: Reply with quote
Hi Dammit,
Talking to Ken at 9Excellence, he warned strongly against using certain types of powder extinguishers. Apparently some are very corrosive and do enormous harm to engine compartments if they are used.
Might be worth investigating?
Mike
Marky911
PostPosted: Fri Sep 22, 2017 4:21 pm    Post subject: Reply with quote
Good updates this week D.
Car must drive brilliantly now. Thumb
maldren
PostPosted: Sun Sep 24, 2017 9:10 pm    Post subject: Reply with quote
Great to meet up and see your car, the suspension is excellent and I was very impressed by the ride, the whole car felt very taught and well controlled.
Looking forward to hearing how your projects develop.
Best Mike
Mike
Y2K
PostPosted: Thu Sep 28, 2017 11:28 am    Post subject: Reply with quote
Great thread and I admire your dedication. Thumb
2001 996 Carrera 2 3.4
1999 Integra DC2
Dammit
PostPosted: Sat Sep 30, 2017 5:40 pm    Post subject: Reply with quote
Thanks!
I called Jenvey yesterday, spoke to a chap in sales, said that I was interested in buying the ITB kit which they make for the M96 engines, and could he send me the technical data on them- found an email this morning (sent yesterday) saying "we don't have any data on them".
I find this surprising.
C4-STORM
2004 Porsche 996 Carrera 4S
PostPosted: Sat Sep 30, 2017 7:42 pm    Post subject: Reply with quote
Hi Dammit.
This is an excellent thread, thank you for posting your updates.
There are clearly 2 schools of thought on the level and rate of expense at which you have committed to.
I don't think it matters either way! It's your car and you are making it perfect for you. Some spend £££'s on modifications, some spend more than others to acquire a later or higher specification derivative in the first place.
I respect what you have done so far, keep the posts coming. Looking forward to your engine rebuild updates Thumb
It is ironic though that you didn't even want a Cab in the 1st place Question
2004 C4S Coupe 3.6 Tiptronic S ~ Basalt Black ~ Black Crested Sports Seats ~ Alcantara ~ S/R Delete ~ WEVO Engine Mounts ~ K&N Induction Filter ~ DesignTek Sports Exhausts ~ Quad Tips ~ RUF Hubcentrics ~ RUF Sports Springs ~ Paddle Shift Steering Upgrade
Dammit
PostPosted: Sat Sep 30, 2017 8:25 pm    Post subject: Reply with quote
Yes, funny that - I'm glad I drove the car though rather than writing it off for being a cab as it turns out I really liked/like it.
As to the expenditure side of things I'm lucky enough to be well paid, it doesn't look like I'm going to have kids - and school fees for the cat are manageable.
I'm also really impatient.
Goto page Previous  1, 2, 3 ... 5, 6, 7 ... 19, 20, 21  Next
Page 6 of 21
