Got in car, closed door with an odd clatter - realised window had not done it's thing.
Neither window switch worked. Memory seat console inoperative, but seats operated fine with own switches.
Car fired up perfectly, normal cranking etc.
"System Fault - Vist Workshop" appeared.
Drove car about and fault persisted. Alarm not working, but central locking all OK.
Later in day tried again and fault had disappeared, and normal function returned. Opened and closed door several times, operated windows, alarm all OK.
A few minutes later got out and back it came!
Did a batt drop/load test and measured 12.5V and 74Ah.
Sounds like a Control Unit failing?
