socket size axle nut
barty40
28 Mar 2016
6
Hello all
I have a split front driveshaft gaiter on my C4
I need to know what size socket is required to remove the axle nut
Anyone who has done this any hints would be appreciated
Many thanks in advance
Can't remember the size of socket but you're going to need a long bar. I use a 3ft breaker bar and slot my jack handle over the breaker bar. It gives me about 7ft of leverage. Last one I did sounded like a gun shot when it cracked.
32mm deep reach, available from Halfords for around £8.
32mm. Doesn't need to be a deep socket. Just done both front inner and outer cv boots on my 4S
Just for curiosity, what should it be torqued up to when you put it back together?
340ft-lbs (460Nm) higher than most people's home torque wrench goes. On my mates C4 we got it to 330Nm and drove it to Centre Gravity who have a huge custom made torque wrench which got about another 1/8 turn on the nut to finish it off.
The normal 32mm socket I had wasn't deep enough due to the driveshaft protruding through the nut hence buying a deep reach one. The deep reach will require less of a extension and keep the breaker bar away from your wheel so less chance of scratching them or your knuckles.
If you weigh 12 stone, stand on a 2 ft bar?!?!?
So anything that will take off a centre lock wheel is more than adequate - if you are ever stuck then go to a local track day : someone will have something that can do it. :thumb:
[Yeah - I am not the only one that keeps a torque multiplier in the car]
124,554
1,441,465
48,968
biel
