Windscreen and headlight washers not working
jhrfc
26 Apr 2016
266
Just about to board channel tunnel and have noticed both aren't working, no pump noise being heard. Yes there is plenty of liquid. Any tips? Do they share a relay/ fuse?
Jon
So headlight washers do work, but screen washers don't.
Could it be a relay?
Pop the nearside headlamp out and get tap the pump while somebody operates the washer jets see if it fires into life. Mine packed in and I did this and it started working but has since stopped working again so just about to order a new one!
Ah will give it a go, I had the lights out to flatten the beams for Europe, maybe that upset something.
You are a star! Worked a treat. I guess this may mean my pump is on the way out.
Cheers again!
Jon
Hi all,
Worth checking with OPC as I recently got a replacement pump with plug (You may have to change the plug on the loom as the new pumps (996 pumps I believe) have different plug connections)) for about £40.
Cheers,
Lig.
124,594
1,441,937
49,026
WilmslowSi
