Scholester said:Get a Pre Purchase Inspection carried out by a specialist with cylinder bore checks included and you should find your answer.
Windy101 said:Scholester said:Get a Pre Purchase Inspection carried out by a specialist with cylinder bore checks included and you should find your answer.
I take your point and can arrange for a PPI, but if it does checkout does the price seem about correct / slightly cheap /cheap / too cheap?
cheshire911 said:As its a private sale you will not have the warranty and protection buying from a dealer gives you. So satisfy yourself that the car is a good one mechanically and has no crash damage or poor repair from such.
Choose a specialist with a lot of marque experience and knows how to interpret the borescope results. Failing that, consider aN OPC 111 point check and pay extra for borescope. OPC will flag up any non-compliant items that are not Porsche original fitment such as battery and then you can use your judgement on the result.
T8 said:If it's got full PSH and is a standard car I'd get the current owner to put an OPC warranty on it before he sells it to you.
The 111 point check and the warranty will cost you about £1300 but it will give you peace of mind worth all of that.
