Yesterday whilst out in the sunshine I went to raise the drivers window and it only moved a couple of inches with a whirr and crunch and and a clunk and then no further movement - I guess the drive cable in the window regulator has broken has anyone had this happen in a Cabriolet as I guess it has implications with raising/lowering the soft top as window closing is part of the sequence.
Luckily I still had the hard top on so I could raise the window by hand but does the regulator and motor have a setting some how as the Cabriolet motor is different to the Coupe.
As well as a replacement regulator instead you can buy a repair kit of just the cable has anyone tried using one of these?
Any Cabriolet owner had this happen?
Del.
Del.
