997 : 2004- 74
996 : 1997-2005 46
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
Locosaki
PostPosted: Fri Apr 21, 2017 4:45 pm    Post subject: Hartech Engine rebuild and all good again Reply with quote
As some of you maybe read last year I had some serious oil pressure issues with my car, I also had a lot of metal fragments in my oil filter, I had only had the car a few months before noticing this, I bought the car without a proper inspection etc so you pay your money and take your chance, I thought the car was cheap enough that's why I didn't get the PPI done.
After some thought I decided I was going to keep the car and get the engine rebuilt, the car went down to Hartech for the rebuild as my thoughts were if I'm spending good money on a rebuild I want it done by a company that specialise in this and I know myself its done right and I'm not waiting on something else engine wise letting go.
Anyway I have to say Grant at Hartech was excellent to deal with, everything from collection right through to delivery of my car was effortless, I've done a few miles with the car now just running it in but already it feels totally different but that was probably more to do with a few underlying problem that Grant and his team had to deal with.
Again if anyone finds thereself in the same position as me, the first thing I did was a little research into second hand engines but most are around 100k which I'm led to believe is rebuild territory, I then started looking about various garages/companies to see what my options were regarding a rebuild in the end I went with Hartech after speaking with Grant. If anyone is in this position I personally would recommend Hartech highly
Carrera 4 MY99 with full Hartech rebuild
edge
PostPosted: Fri Apr 21, 2017 6:19 pm    Post subject: Reply with quote
Good to hear that everything has been sorted with the Engine, all that leaves now is for you to enjoy driving your 911.
Sold 2004 Boxster S
Sold 2006 997S
Sold 2008 GT3
Sold 2009 Boxster S
Sold Red 2013 981 S
Black 997 Gen2 Turbo
Shanghai
PostPosted: Fri Apr 21, 2017 7:00 pm    Post subject: Reply with quote
Some good news at last Thumb
At an Indy these days !
Halcyon
PostPosted: Fri Apr 21, 2017 7:09 pm    Post subject: Reply with quote
I have to ask Locosaki...
How much? Thumb
996.2 Carrera 4 Convertible Tip
Locosaki
PostPosted: Sat Apr 22, 2017 11:02 am    Post subject: Reply with quote
Yeah just a case of driving it and enjoying it now.
Dermot, thanks for the help and advice on previous posts hopefully now I shouldn't have any major issues.
Cost wise, there are lots of variations as to what can be done and what needs done, Hartechs website is a good indication of costs but mine needed a crank over and above getting it rebuilt.
PGR
PostPosted: Sat Apr 22, 2017 12:14 pm    Post subject: Reply with quote
Did Hartech provide a used crank, or did you have to buy a new one?
Locosaki
PostPosted: Sat Apr 22, 2017 12:33 pm    Post subject: Reply with quote
Yeah Hartech provided the crank, not sure on costs of new crank but if they can still be had I'd imagine they'd be quite a few thousand pounds.
At this stage I went with the newer style IMS set up from the newer car, not quite sure on the ins and outs but that's what I had done, quite sure someone with more knowledge could elaborate more.
alex yates
PostPosted: Sat Apr 22, 2017 12:47 pm    Post subject: Reply with quote
Hartech will upgrade the original ims bearing to the later final 997 design by modifying the ims sprocket and spigot to accommodate it.
Peace of mind that your new rebuilt engine will not go pop due to the smaller bearing.
Worth every penny. Thumb
Used daily....rain, sun or snow.
PGR
PostPosted: Sat Apr 22, 2017 1:01 pm    Post subject: Reply with quote
I think new cranks are around 3k. My car is at Hartech at the moment, and I'm hoping it won't need one!
Dammit
PostPosted: Sat Apr 22, 2017 1:48 pm    Post subject: Reply with quote
The potential need for a crank etc is why I have been thinking of having the rebuild done at 80,000 miles (on 62,000 right now) hopefully with the engine running healthily at that point- my goal being to only require replacement of the consumables as it were, albeit that that includes the cylinder barrels.
Using advanced man maths this makes things cheaper by avoiding a larger expense- which might never come, of course.
Poker2009
PostPosted: Sun Apr 23, 2017 8:42 am    Post subject: Reply with quote
What sort of cost are you looking at for a "refresh" at 80k miles? What is the potential saving if it was the "worst case" failure scenario?
Its not really a bad idea, especially if you can combine it with things such as clutch, water pump, spark/coil packs, tandem pump etc
Porsche 997.1 C2S Basalt Black
EGTE
PostPosted: Sun Apr 23, 2017 10:26 am    Post subject: Reply with quote
I too would be very interested in this: it does make sense, but only at the right price (and engine size Grin ).
Locosaki
PostPosted: Sun Apr 23, 2017 11:02 am    Post subject: Reply with quote
If you think about price I don't think it does make finical sense to fix a 10k car with a 10k rebuild but then again someone has to do it.
I'd imagine a fair few people would end up breaking the car ( I gave it serious consideration) if this does turn out to be the case then a good one will be harder to come by, that was the logic behind my thinking
alex yates
PostPosted: Sun Apr 23, 2017 11:08 am    Post subject: Reply with quote
All prices are here: https://www.hartech.org/rebuild-prices
But at a guestimate, if you send the car to them and they do a full engine strip, replace all seals, gaskets, etc. New oil & filter, road test (the full monty on just a strip and rebuild) & also add on crankshaft bearing set, stronger IMS spindle and (normal) bearing with seals removed & timing chain set you're looking in the region of just shy of £5k including VAT.
Dammit
PostPosted: Sun Apr 23, 2017 1:50 pm    Post subject: Reply with quote
My plan was to do the above but also go to 3.7 litres, as I'd be having the barrels replaced anyway.
alex yates
PostPosted: Sun Apr 23, 2017 1:59 pm    Post subject: Reply with quote
Budget £12k then.
Dammit
PostPosted: Sun Apr 23, 2017 3:01 pm    Post subject: Reply with quote
Significantly less than that was what I was told on the phone- however the 3.7 litre offering isn't yet signed off so this is all subject to change.
At 5,000 miles/year I've got plenty of time for Hartech to finalise things.
alex yates
PostPosted: Sun Apr 23, 2017 3:40 pm    Post subject: Reply with quote
Base Engine Rebuild (Car & Engine): £3500 + VAT
Option d) 6 x New Cylinders: £2500 + VAT
6 x New Piston: From £169 + VAT (From £1014 + VAT)
New Latest Design Porsche Intermediate Shaft: From £750 + VAT
(no brainer if you're going up to 3.7)
New Crank Shaft Bearing Set: From £120 + VAT
New Timing Chain Set: From £222 + VAT
Total - (from) £8,106 + VAT = £9,727
I'm assuming here that everything needed for a 3.7 is the cost on their website, although I'd have thought some price increase on those base costs. Dont know
As I said - budget £12k. Once you've had a new clutch and flywheel fitted whilst they're in there and a new AOS + any other stuff they'll recommend (as the originals will be jiggered) then £12k will be in the right ball park.
Locosaki
PostPosted: Sat Jul 15, 2017 3:49 pm    Post subject: Reply with quote
Well that's me 2k in on the rebuilt engine and what I was told would have it run in, I had my last 200 miles to do yesterday so took the day off and went for a blast round some cracking roads around Lochearn head, Killin which is not far from Perth.
Apart from one problem the first 2k have been problem free so long may this continue, to be fair the problem I had was with evap set up and not engine related really.
Today I dropped the oil and filter and moved over to miller's 10/50, I opened up the oil filter out of curiosity as the last time it looked like a glitter ball, today there was absolutely nothing too see.
I have to say that in the time I had the car before the rebuild it wasn't what I would class as impressive power wise but now it goes well and I also now don't have the fear of something going bang when pushing on a bit.
The Lone Ranger
PostPosted: Sat Jul 15, 2017 4:14 pm    Post subject: Hartech. Reply with quote
From what I understand , the cost of a precautionary rebuild, that people have mentioned is in the region of £10k. Obviously could be more dependent on what is required. Some people have said that around the 80k is a good point, but its a lot of money if your car is running faultlessly at 80k. Tough decision really. Question
