997 : 2004- 69
Boxster : 1997- 13
Cayman : 2005- 14
shotfox
PostPosted: Fri May 12, 2017 12:54 pm    Post subject: Reply with quote
Great work. Hoping to see if I can use this to install the Parrot Smart. Do you know if there is any requirement in the new head unit or should I be able to connect anything?
Mezgerite
PostPosted: Fri May 12, 2017 1:06 pm    Post subject: Reply with quote
put your head behind the AC controls with the carpet sections removed and you will see a multiplug. Into it a thick orange wire - you can't miss it Smile
stefant
PostPosted: Fri May 12, 2017 2:54 pm    Post subject: Reply with quote
This is only on US Spec cars. the UK cars don't have it for some reason...
maldren
PostPosted: Sat May 13, 2017 7:52 am    Post subject: Reply with quote
Not sure where this came from but the Pelican site info is based on US spec LHD models and the layout behind the dash is inevitably different.
Mike
Mezgerite
PostPosted: Sat May 13, 2017 8:28 pm    Post subject: Reply with quote
This is on 997 UK spec - not sure about the 996!
msjdoak
PostPosted: Wed May 15, 2019 12:28 pm    Post subject: Reply with quote
For the Power Switched - how did you connect the power from the switched power source to the new equipment?
Did you just connect that power to the new head unit only, or did you connect the power to the red wire on the Connects2 module as well?
stefant
PostPosted: Fri May 17, 2019 8:28 am    Post subject: Reply with quote
I ran it from the fuse box, finding a switched live
Goto page Previous  1, 2
Page 2 of 2
