991 : 2011- 19
996 : 1997-2005 33
993 : 1993-1998 7
Cayenne : 2003- 4
stefant
PostPosted: Tue Apr 18, 2017 3:52 pm    Post subject: The end of my PCM2 - upgrading Reply with quote
Enough is enough! Having replaced the drive in my PCM2 due to it not reading the Nav discs, or any discs properly. I have now had multiple error messages and it keeps forgetting the coding for the telephone model, do can't use my Dension anymore.
I pulled the trigger and ordered the following:
Replacement headunit, with apple CarPlay - Kenwood DMX-7017DABS
Adaptor to allow me to keep the stock amplifier and speaker connections
Dash surrond to allow flush fitting of the head unit.
I am going to install it all this weekend so will keep you posted. I did a lot of research so if it goes well will be happy to share... Wish me luck!
Halcyon
PostPosted: Tue Apr 18, 2017 5:35 pm    Post subject: Reply with quote
Good luck! Thumb
(Though I would have replaced the amp and speakers too) Mr. Green
996.2 Carrera 4 Convertible Tip
maldren
PostPosted: Tue Apr 18, 2017 7:59 pm    Post subject: Reply with quote
Hi Stefant,
Is it an early car or a later MOST car?
Mike
Mike
New997buyer
PostPosted: Wed Apr 19, 2017 6:20 am    Post subject: Reply with quote
Go for it. I fitted this courtesy of a lovely fellow member who was a joy to trade with (cheers Ben Thumb ).
Tips? Get the right connector if MOST. Mine wasn't cheap but importantly everything works. If fitting yourself make sure the settings are left at neutral on your PCM before removal (Volume to mid, faded and balance to mid etc).
And make sure you've set all your car functions that the PCM controls as you like them before removal (lights, wipers, door locking etc).
Like many I've gone down the Brodit route for my phone holder (damn you Spiderlane Damn ).
And that's that. Great upgrade on functionality thumbsup
stefant
PostPosted: Wed Apr 19, 2017 7:18 am    Post subject: Reply with quote
Yes it is the Most version, got the right adapter
Thanks for the tips
stewhp
PostPosted: Wed Apr 19, 2017 8:18 pm    Post subject: Reply with quote
Really looking forward o hearing how you get on and how easy it is as a diy change out.
Could you post some pics of the MOST adaptor when fitting.
This is on my list of things to do n the future.
Current car: 996 Carrera 4S, Carrara white
Previous cars:964 Carrera 4, 964 Carrera2
964 Turbo 3.6
New997buyer
PostPosted: Wed Apr 19, 2017 8:28 pm    Post subject: Reply with quote
Stewhp - this is the MOST adaptor for the 997.1 turbo.
http://www.nav.tv/products/porsche-pcm2-21-head-unit-replacement-por-hur
Not sure if its what you need but give them a call as they were very helpful to me Thumb
Stefant - welcome. thumbsup
stefant
PostPosted: Thu Apr 20, 2017 6:59 am    Post subject: Reply with quote
This is the adaptor I went for. Recommended by the place I bought the rest of my kit from, and cheaper than the post above.
http://www.connects2.co.uk/Product/ProductItem/CT51-PO04
Bought everything from car Audio direct who where very good to deal with
I will post some pics as I go along.
stewhp
PostPosted: Thu Apr 20, 2017 7:00 am    Post subject: Reply with quote
Thanks for the info. The adaptor is for a PCM2 in a 2003 996 with Bose.
Cheers.
964 Turbo 3.6
stewhp
PostPosted: Thu Apr 20, 2017 7:04 am    Post subject: Reply with quote
Thanks Stefan hope it goes well.
964 Turbo 3.6
JH
PostPosted: Fri Apr 21, 2017 2:27 am    Post subject: Reply with quote
Good luck with the install. The PCM 2 really is pretty bad compared to modern kit.
Does the use of a MOST Adapter impact the dashboard computer display of mpg, tank range, boost pressure, temp etc? I would expect it to impact the satnav part of course, but what about the rest of the functions?
S4ch
PostPosted: Fri Apr 21, 2017 10:14 am    Post subject: Reply with quote
Looks very nice. How do you find the sound quality with the existing speakers? Is it any better via the new head unit?
Sad
stefant
PostPosted: Fri May 12, 2017 7:11 am    Post subject: Reply with quote
Right apologies I haven't posted an update sooner, but here goes.
The conversion kit I bought is sold by connects2 as plug and play, they are very helpful when you call then for sales advice or technical support - however due to the number of variations in 996 cars they can't guarantee that every car will plug and play. Mine was not!
This wasn't really an issue as all it meant was that the switched power (from the ignition switched on) needed to come direct from the fuse box as the convertor was not sensing the can bus was turned on.
Other finings is that the 996 has two anntenna one in the windscreen, which needed power to work and one diversity, which is a non powered and under the plastic cowling by the windscreen wipers.
The one you want to use for your new stereo is the windscreen powered one, the diversity can't be used.
I installed DAB and used a small whip type antenna under the the plastic cowling by the windscreen wipers, I actually made it lie over the diversity antenna. The signal is fine and avoids having the awful windscreen mounted version.
The DIN to existing Porsche antenna adaptor (CT27AA14) has a power wire on it that is not needed as the power comes through the existing cars wiring harness and your new head unit.
Other than that it was pretty easy. The surround for the new head unit kit, again fro connects two is very good.
Wis post some pics latter
stefant
PostPosted: Fri May 12, 2017 8:42 am    Post subject: Reply with quote
some more information here. Please message me if I can help anyone with further information...
the wiring diagrams I used are here:
http://www.tehnomagazin.com/Auto-radio-car-connector/PORSCHE-Car-Radio-Wiring-Connector.htm
On mine I only had plugs A and C, plus the orange Fibre optic cables.
Sound:
The connect2 convertor turns the Fibre into normal RCA plugs so you can attach to your new headunit.
Power Switched:
The convertor attempts to use Plug C pin1 and 2 to control the ignition on. This didn't work on mine so they suggested I simply ignore it - which I did and routed the power from a switched power source in the fuse box.
Power Constant:
Plug A contains the constant power and antenna power (pin 5) which you simply connect to the antenna power of your new head unit and plug into the convertor
Antenna:
I used a convertor so I could convert the Porsche antenna into the standard Din of the new headhunt. this is just plug and play (ignore the blue powered from the antenna convertor as this is not needed due to the power for the antenna coming from the PlugA pin 5 (see above)
https://www.renntech.org/forums/topic/35903-pcm-antenna/
GPS:
My Head unit came with a GPS antenna (Small square one) this looked the same as the porsche one that is mounted under the alarm light in the centre top of the dash. I did buy a convertor for this but in the end decided to simply swap out the Porsche one for the new Kenwood one, which was easy to do.
]https://www.renntech.org/forums/tutorials/article/20-pcm-2-installation/
Half way down the page on the link above it shows you how to swap them over.
DAB:
I bought a small thin GPS antenna from here:
http://www.dabonwheels.co.uk/Kinetic_MagnetwiG__DMA-1004_DAB_car_aerial.html
I routed it to under the cowling on the right hand side by the pollen filter (as you stand in front of the car looking at the windscreen). I wedged it into the diversity antenna that may or may not help with the reception - it has been fine up to now.
Double Din cage:
I bought this kit again from Connects2. Use the part number on my original post as connects2 tried to give me the part number for the 997!.
It fits well, but I took advice from another forum and added some screws on the left and right side to hold it tight, I didn't think the bend over clips would secure it.
Headunit:
I am very pleased with the headunit. The sound quality is great as is CarPlay. you can customise the colours of the keys and the background to match your car.
Other:
Don't forget to connect the handbrake cable from the headunit to the negative power to trick the unit that the handbrake is on (loads of details about this on the web)
Connect the dimmer cable from the head unit to the cigarette lighter illumination cable to dim the unit when the lights turn on
Connect the Antenna power cable from the head unit to the cars antenna cable
stefant
stefant
Mezgerite
PostPosted: Fri May 12, 2017 10:18 am    Post subject: Reply with quote
I have just gone through the same thing with a Kenwood DAB/GPD unit.
My connects2 module also did not provide a switched live. There is an orange wire behind the center console that is live with key on ignition. I used this so that it works like OEM and switches off when you pull the key out. DAB i'm using the windscreen mount in the top left corner. I may change to a different style though.
Now i need to check if I need to enable the Inrix DAB bases HD traffic.
Rick
deckster
PostPosted: Fri May 12, 2017 11:24 am    Post subject: Reply with quote
stefant wrote:
DAB:
This sounds interesting...I was looking at getting a DAB head unit but couldn't get my head around what I'd need to do for the aerial. A neat install like this is just what I'm after - was the routing easy to do? Do you have any pictures?
stefant
PostPosted: Fri May 12, 2017 12:36 pm    Post subject: Reply with quote
deckster wrote:
stefant wrote:
DAB:
Routing was dead easy. Behind the battery is a large grommet that I routed the DAB antenna wire through (be careful not to push the grommet into the car)
stefant
PostPosted: Fri May 12, 2017 12:37 pm    Post subject: Reply with quote
Rick
That is interesting as I looked everywhere for a switched wire behind the dash. In the US they have the telephone cable and plug there, that they all tap into. Where was the orange wire in the UK car?
