997 : 2004- 66
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Classic : 1950-1965 1
Boxster : 1997- 15
Cayenne : 2003- 9
912-914-924-928-944-968 4
ger
PostPosted: Sat Apr 15, 2017 4:22 pm    Post subject: Ticking 996 Turbo Reply with quote
I have a track day booked on Wednesday and am rather concerned about the car. This ticking has been evident For around 60 miles and doesn't appear or diasappear with oil or engine temperatures. It only varies from RPM.
I have had bad luck with a snapped timing chain and an IMS failure in the past (different cars) so am very anxious.
Have a listen..
https://youtu.be/sTRR7cpcxTg
Greg
Black 996 Turbo manual (9e2?)
Midnight Blue 996 GT3 MKII CS - SOLD
Cobalt Blue 996 Cab - SOLD
Cayenne Turbo - SOLD
2004 996 C2 40th Anniversary Edition No. 242 - SOLD
Demort
Estoril
PostPosted: Sat Apr 15, 2017 4:31 pm    Post subject: Reply with quote
It sounds like a tappet to me but i would prefer to have it on a ramp to diagnose and as you are going to track it then i think you should get it checked out prior to that .
At an Indy these days !
PostPosted: Sat Apr 15, 2017 6:17 pm    Post subject: Reply with quote
Agree with the above, I would not track the car until its checked out.
Black 997 Turbo Manual, 9e supplied
Black 997 C4S Manual
Jonathon555
PostPosted: Sat Apr 15, 2017 7:53 pm    Post subject: Reply with quote
Noisy injector ? Or tappet would be my guess. But i am sure an expert would be first port of call
JM30
PostPosted: Sat Apr 15, 2017 8:56 pm    Post subject: Reply with quote
Possible Water pump failing it sounds like? ticking / tapping noise, get it looked at to be sure as i'm sure you will be.
Mac996t
2004 Porsche 996 Turbo
PostPosted: Mon Apr 17, 2017 11:20 pm    Post subject: Reply with quote
I was going to say they all sound quite tappy but then realised it's only just appeared!
Something else I would add to the check list is a check of the exhaust and manifolds in case its blowing anywhere, any idea what condition the nuts are in on your car. There are lots out there where some of the nuts have corroded away to nothing !
Mac
poppopbangbang
PostPosted: Mon Apr 17, 2017 11:33 pm    Post subject: Reply with quote
Does sound tappety but then there are lots of things on all 996 and 997 that can sound like that which aren't actually that....
That is probably the most unhelpful sentence ever! I don't think we have a trackday on Wednesday but just in case we do and you are at Bedford I'm in on Wednesday, we are next door to the trackside suite (where you sign on) so feel free to pop over and knock on the workshop door, I'll have a listen for you.
ger
PostPosted: Tue Apr 18, 2017 9:39 pm    Post subject: Reply with quote
Thanks for all the help everyone, it's always a concern when anew noise develops!
I was booked up at Snet tomorrow but have cancelled.
I'm putting the Turbo into my trailer in the morning and taking it down to 9e. The engine was built by the team so they know it well. Hopefully it's something minor.
I shall keep you posted.
thumbsup
Diggermeister
PostPosted: Thu Apr 20, 2017 7:56 am    Post subject: Reply with quote
Probably the best decision.
As others say, there are a lot of things on a turbo Mezger that can make noises - they're renowned for being clattery at the best of times - and a good expert (9e would obviously rank as such) will diagnose it pretty easily.
I've currently got a tiny pinhole in my O/S header which is impossible to get a welder into (non OEM stainless manifolds) and that makes a ticking noise, but only at tickover.
ger
PostPosted: Thu May 04, 2017 6:15 pm    Post subject: Update Reply with quote
It was a broken exhaust tappet.
Apparently this is one of those things, fairly unlucky.
Replaced all six and converted to 2WD and GT2 clutch whilst the engine was out.
Pork hobby is expensive!
plynchy
PostPosted: Fri May 05, 2017 8:46 am    Post subject: Reply with quote
That's one hell of a 'while the engine is out' job! Floor
I got my water pump changed Embarassed
'02 996 Turbo Manual Coupe Lapis/Grey. Unlimited grins.
snb993
PostPosted: Fri May 05, 2017 9:07 am    Post subject: Reply with quote
good job you didn't take it on track Surprised
still, according to my personalised copy of 'the expert guide to man maths', it suggests that the money saved from not having your engine misbehave on track can be allocated to offset against the 2WD and clutch! Grin
996T - Cobalt blue, K24's, GT2 I/C's, Techart SSK, Manthey KWv3, RS engine mounts, Europipe, GT3RS 6 pots, 997T discs/RS29's all round etc
964 C4 - GP white, 993 C4 gearbox/front diff, Wayne remap, Bilstein B6's / H&R springs, polybushed, Cup 1's, RS SSK, gutted cat etc
993C4 - sold
928S4 - sold
