997 : 2004- 79
996 : 1997-2005 40
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 9
Cayenne : 2003- 4
912-914-924-928-944-968 3
993S_Ocean
1997 Porsche 993 Carrera 2S
PostPosted: Tue Apr 11, 2017 3:01 pm    Post subject: Does your clutch pedal occasionally stick slightly? Reply with quote
For those that drive your cars... do you ever find the clutch pedal doesn't always fully come back to the position it should? Have you found out why and managed to cure it? [/list]
cableguy
PostPosted: Tue Apr 11, 2017 3:08 pm    Post subject: Reply with quote
Mine does this intermittently, however not so much as to bother me. I've actually got into a habit of flexing my ankle at the top of its release which brings it to its full resting/extended position.
C.
Pork!
tim993
PostPosted: Tue Apr 11, 2017 3:19 pm    Post subject: Reply with quote
not heard of this but just to rule another thing out - is the action still smooth? Notchy pedal action is also associated with a worn clutch actuator cylinder and or a worn out clutch...
"I don't know what it is about peace conferences, but they always seem to attract terrorists, extremists and nutterists."
1995 993 turbo
2015 981 GTS
pietrzj
PostPosted: Tue Apr 11, 2017 4:00 pm    Post subject: Reply with quote
I believe this to be not an uncommon problem. There are fixes and I think the Pcarworshop.com has an article on this under the 993 section here
http://www.pcarworkshop.com/index.php/993_-_Clutch_Pedal_Service_and_hanging_problem
GT4
Nordschleife
Nordschleife
PostPosted: Tue Apr 11, 2017 4:08 pm    Post subject: Reply with quote
Kinematic lever issue or pivot corrosion
Tobesetc
PostPosted: Tue Apr 11, 2017 4:30 pm    Post subject: Reply with quote
Mine does it intermittently and last time we were out Rob was complaining that his does too.
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
martinfc
PostPosted: Tue Apr 11, 2017 8:09 pm    Post subject: Reply with quote
I had this problem when I bought the car in 2011, Northway changed the slave cylinder and it was fine for a few years, then started again.
After a bit of digging found this:
http://p-car.com/diy/pedal/clutchlever.html
Had the new kinematic lever fitted and all is now fine - time will tell if it stays that way Smile
HTH
Martin
1994 C2 NB Pre-vario
9xxnick
PostPosted: Thu Apr 13, 2017 1:05 pm    Post subject: Reply with quote
I replaced the kinematic lever for exactly this reason. My car is probably not untypical of a 993 in that the dust boot on the clutch master cylinder had failed possibly some years before and the whole area was quite dirty from footwell dust.
I took the whole assembly out, dismantled and greased it where appropriate, and fitted a new clutch master cylinder.
Everything has worked beautifully for the three years and 15,000 miles since then.
Endoman
PostPosted: Sat Apr 15, 2017 1:40 pm    Post subject: Reply with quote
Mine stuck down fully, not nice. Most recent kinematic lever, new master, MPL slave and new flexy fitted by self. The master was the worst part as access is dificult getting the hard line reconnected. Changeing the slave was made easier by lowering the engine/gearox slightly and using some thinwall brass tubing to align it. Some excellent posts on tint if you fancy diy. Sometimes just a bleed will cure it.
Jack Frost
PostPosted: Fri Apr 21, 2017 7:44 pm    Post subject: Reply with quote
Yeah, mine done this when I got it. Northway suggested new slave and flexi = all good now.
stuttgartmetal
PostPosted: Sun May 07, 2017 8:44 pm    Post subject: Reply with quote
Mine squeaks
As did the pedal on my last one.
Tobesetc
PostPosted: Mon May 08, 2017 10:47 am    Post subject: Reply with quote
Dropped my car in for its annual service today and mentioned this issue. Steve said they have a redesigned part with a new shaped lever that stops exactly this issue, so getting that fitted.
sram
1995 Porsche 993 Carrera 2
PostPosted: Mon May 08, 2017 1:09 pm    Post subject: Reply with quote
I suffered this since first buying the car in 2009 and had various indies take a look. They all had an idea on what caused the problem and over time I had both the master and then the slave cylinders replaced on their recommendation. Very little improvement. I then tried an MPL cylinder and it was the same. I had the new style lever fitted and it was better but not perfect.
Then, the 993 genius that is @colt on here suggested he had finally found the cause of the issue. He rebuilt the pedal box and replaced a couple of pieces that he identified had barely perceptible wear. It's been over a year since I had this done and I've not had the pedal refuse to come all the way home again. It also stopped the bloody squeak every time I de-clutched which was beginning to drive me mad. It's the little things like this that can really detract from the driving experience, especially when sat in traffic.
hth
993 C2 Manual. Iris Blue
Maintenance blog - http://bit.ly/hPyiBV
Previously: Elise S2 111S, BMW Mini, MG Midget
boo
