Heater bypass mod
10 Mar 2007
558
Hi trying to source the correct part for removing the heater blower and fitting the bypass pipe. Type 911 are out of stock ad design 911 don't have the fan shroud. Do you need the fan shroud part for the pre vario cars ? Anybody done this mod recently I think it saves about 4kg thx
Heater bypass part no. is 99321194100 Its £166 plus VAT from my local porsche shop, so much more expensive than the carbon ones from Fabspeed (and sold by Design911) @ about £119 + vat.
I was after one, but it will have to wait. Not sure if you need the shroud. I have a pre-vario and it doesn't look like I need one.
I felt the carbon one would look a bit out of place.
Maybe a scrappy would have one, or Jasmin porsche?
Jan
HI found one on rose passion for 134 euros but it doesnt say if you need the shroud cover for the non vario cars.. I heard its a ***** to fit judging by the articles on rennlist :dont know:
I did this, was a prick to fit... I loved the way it remoed 'bulk' from the engine bay.
It messes with your Air Con a little, but no massive issue..
However, Wayne the master tuner from Chipwizards warned against them... he said he's seen them put stress on xxxxx... I can't remember what xxxx was but I immediately removed mine.
So perhaps consider how much you want this.
You don't get the blower cooling the crankcase when you stop. I've had mine on for about 4 yrs with no problems. Proper RS one now, used to have a Fabspeed one, the carbon ones do look better but are a swine to fit. I did a mod to the hvac wiring ref ToreB which gives full front blower funtion, the other fixes did not work consistently. With the road layout locally the car has plenty of time to cool after a blast.
124,558
1,441,504
48,971
Bristolsparks
