997 : 2004- 68
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Classic : 1950-1965 1
Boxster : 1997- 15
Cayenne : 2003- 9
912-914-924-928-944-968 4
llangford
PostPosted: Sun Apr 09, 2017 8:38 pm    Post subject: 996 Front suspension - do I need to replace these? Reply with quote
Hi All,
Looking at my front suspension today & I noticed the passenger side one of these is perishing while the drivers side is ok. Should I be worried and/or should I replace them? (and what are they called?)
car is a 996.2 2002 with 29k.
[/img]
The car was serviced by Porsche East London 4 weeks ago and they didnt say anything about it....
ELA
PostPosted: Mon Apr 10, 2017 5:52 am    Post subject: Reply with quote
They are called bump stops and I've seen a lot worse. You can carrying on driving will no ill effects if you so wish.
1275kg 997GT3RS with:
Kessels 458bhp 3.8l & vgs-MS ECU
Akrapovic titanium exhaust
Cup 9:35 diff, Airbox, PAS, front lip
BBS 19's
H&R Suspension
Carbon wings/doors/bonnet/door cards
bakerboy4s
PostPosted: Thu Apr 20, 2017 5:04 pm    Post subject: Reply with quote
OPC told me top mounts need replacing as they are separating, what exactly do you get when you buy top mounts, is it the whole shebang or just the supporting mount plate?
Demort
Estoril
PostPosted: Thu Apr 20, 2017 6:18 pm    Post subject: Reply with quote
Bumps stops and no you dont need to change them , wait untill you need other shock abs work .
Top mount and its the plate with the bush in it although most places would replace the bearing as well at the same time along with anything else that was needed , OPC should really give you a break down of the parts they are quoteing for .
At an Indy these days !
