997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 14
poppopbangbang
PostPosted: Sun Apr 09, 2017 8:18 pm    Post subject: It's Back - 3.7 Content *Now With Prelim Results* Reply with quote
So my old knacker came back on Friday, I was meant to go and get it about a week earlier than this but everything that could kick off has kicked off at work and I've been a bit snowed under!
At least it was a nice weekend for it! Very Happy
I'm putting some gentle miles on it at the moment ready for heading to the dyno late next week to see what it will make. It has A LOT more low RPM torque than it ever did previously which is going to be due to the extra 300CC and valve seats that aren't half a million KMs old Laughing
From the original engine we kept the castings, crank, rods, inlets and exhaust manifolds and that's about it. Full list of everything that went into it as follows:
- Original 3.4L block/crankcase machined by Capricorn to carry 100mm bore liners converting it to a closed deck design with additional machining work to provide additional coolant flow around the liner tops.
- CP 100mm 3 ring forged pistons with reduced skirts to minimise frictional losses.
- Original 3.4L heads rebuilt and mildly fettled with new valve seats, single piece valves, new Porsche lifters, springs, retainers etc. new standard spec cams.
- Every chain, guide and associated parts replaced with new Porsche supplied bits.
- Big ends and mains replaced with new Porsche supplied items.
- IMS bearing converted to pressure fed roller bearing - best option given the OE dual row is NLA.
- Original rods crack tested and fitted with ARP fasteners.
- Every gasket and o-ring seal (no matter how small) replaced with new Porsche supplied bits.
- Twin chamber Porsche "Motorsport" Air oil seperator fitted in place of standard item.
- All fasteners replaced with new.
- All belt rollers, tensioners etc. replaced with new.
Oil system and cooling system carried over from the old engine as these clearly worked very well indeed along with the GT3 throttle body, low loss intake and equal length exhausts. Given the heads now flow a bit better and the valves are less shrouded from the larger bore, it has another 300CC and less frictionals I'm hoping it will make similar power to a Mk1 GT3. We'll find out next week Laughing
My main aims with this motor were to make a better road car version of the M96, considering the mileage it had managed there wasn't a lot to do reliability wise but I did want to find some more performance without compromising its road manners, going larger bore and doing this with capacity rather than cams etc. is really the only way to do this as I really didn't want to end up with a peaky engine that needed revs to make good torque. It is afterall a road car used for lots of long journeys so needing to string it out to the last shift light all the time is tiring at best. I also really didn't want to go up in stroke (hence not using the 3.6 crank to make a 3.9) as in my experience those engines with the lowest mean pistons speeds generally live the longest. With a 78mm stroke and a 7250RPM limiter the worst case mean piston speed is still only 18.85MPS which is pretty low all things considered and should lead to a happy and long lived engine Very Happy
I think that is about it now for modifications aside from building a display into where the rev counter currently lives I have no more plans for the car aside from pile the next 300K miles onto it as quickly as possible.
It is so nice to have the old girl back on the road Very Happy
PostPosted: Sun Apr 09, 2017 8:28 pm    Post subject: Reply with quote
Pop Corn
PostPosted: Sun Apr 09, 2017 8:32 pm    Post subject: Reply with quote
PPBB Great read mate, car looks lovely and a fantastic well thought out rebuild. Thumb Thumb
911tom
Watkins Glen
PostPosted: Sun Apr 09, 2017 8:40 pm    Post subject: Reply with quote
What a story your car is! Please keep us all posted.
996 Turbo - Link to my 3.8L turbo build thread
2011 Cayenne
718 Cayman GTS
350Bhp astra van for work, semi-retired from daily duties
2009 Ariel Atom 3 Supercharged SOLD but never forgotten
Dammit
Watkins Glen
PostPosted: Sun Apr 09, 2017 9:14 pm    Post subject: Reply with quote
Great news, did the rebuild come in according to your budget?
poppopbangbang
PostPosted: Sun Apr 09, 2017 9:18 pm    Post subject: Reply with quote
Yes no surprises or dramas. Autofarm were great to deal with, as they always have been in my experience. I think we were a bit under budget in the end.
996lee
PostPosted: Sun Apr 09, 2017 9:21 pm    Post subject: Reply with quote
Cool
Look forward to seeing the dyno results Thumb
2001 Carrera 4 aero all the way!!
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Apr 09, 2017 9:38 pm    Post subject: Reply with quote
What made you decide to go with a roller bearing, I would have gone with a single row and spaced it due to lateral movement if the dual row wasn't available?
Looking forward to the hp figures with a 3.7.
kurlykris
PostPosted: Sun Apr 09, 2017 9:49 pm    Post subject: Reply with quote
It will be interesting to see your dyno results and general improvement with this upgrade, I`ve been thinking of doing the same thing Thumb
What were the costs involved if you don`t mind disclosing, via PM if necessary Thumb
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
poppopbangbang
PostPosted: Sun Apr 09, 2017 10:10 pm    Post subject: Reply with quote
Do you mean axial movement? If you do mean axial then the FAG TB type bearings have an axial load capacity of 60% of their radial load capacity so there is little point using a single row bearing for axial load handling reasons when you can do it with a roller bearing. We've used the same bearing design in F1 gearboxes where they have very high transient axial loads with great success. Plus as a company has put their money where their mouth is and paid to have a specific TB type bearing made to do this job it seemed rude not to give it a go, what's the worst that can happen Laughing
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Sun Apr 09, 2017 11:37 pm    Post subject: Reply with quote
Axial is probably the word I was looking for, although I'm not a mechanical engineer, I do hope that roller bearing solution works out.
Gearboxes are quite tight in their axial movement compared to the IMS design on a 996 which almost floats in comparison. LN put their companies reputation on their ceramic bearing some years ago but ended up denying all responsibility for the engines that failed due to the design so I'm not sure the roller is the tried and tested route yet?
poppopbangbang
PostPosted: Mon Apr 10, 2017 12:04 am    Post subject: Reply with quote
Road car gearboxes are.... a 2K onwards F1 box with a gearbox mounted clutch and first and second motion shafts that are essentially fully floating in the bearings at certain points in the gear change is something quite different Very Happy
PostPosted: Mon Apr 10, 2017 5:59 am    Post subject: Reply with quote
Snap.
I'd've been tempted to leave the original in once measured for play. Was there any noticeable wear on it PPBB?
ELA
PostPosted: Mon Apr 10, 2017 6:35 am    Post subject: Reply with quote
Sounds just about the perfect solution ppbb Thumb
Knowing you I'm sure you managed to do the running in miles within an afternoon Grin
Look forward to hearing how the performance compares once you have the chance to really open her up
CLR996 1086kg bespoke design
Harv
PostPosted: Mon Apr 10, 2017 8:18 am    Post subject: Reply with quote
Really good to hear she's back up an running PPBB Thumb
PostPosted: Mon Apr 10, 2017 9:18 am    Post subject: Reply with quote
Agree
Great stuff!
BHZ661
PostPosted: Mon Apr 10, 2017 9:27 am    Post subject: Reply with quote
Looking forward to the updates . thumbsup
Y2K
PostPosted: Tue Apr 11, 2017 10:09 pm    Post subject: Reply with quote
+1
Great to see the car back.
2005 996 GT3 mk2
1999 Integra DC2
crash7
PostPosted: Wed Apr 12, 2017 8:29 am    Post subject: Reply with quote
PPBB
Off-topic, could I ask what ride heights are you running on your car?, taken form the Porsche suggested points.
How close is your FVD oil pan to the floor with those heights?
Marky911
PostPosted: Wed Apr 12, 2017 9:39 am    Post subject: Reply with quote
Looking good poppop. Good to see it's back.
What benefit does the Motorsport AOS have please? And how does it compare price wise? I know most Porsche Motorsport parts are usually cheaper.
I'm interested in the IMS bearing goes as the roller type is top of my list should I need to change mine.
Goto page 1, 2, 3  Next
Page 1 of 3
