Hi guys,
As per the title, on the motorway cruising at steady 85 and Amber warning light appears, steady not flashing.
Took it easy into I pulled onto drive and noticed back end of car covered in coolant and tank emptying remaining contents.
Unable to see exactly where the leak-if that's what it is- is coming from.
Car felt a little sluggish and slightly rough idle albeit not misfiring on way home. Any ideas as to what it could be and could the amber warning be linked to the lodd of coolant? Water temp was constant 90 even when home.
Oil filler cap very mayo, I'm thinking head gasket maybe :-(
Thanks in advance for any help.
