996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
decgraham
PostPosted: Mon Mar 20, 2017 7:30 pm    Post subject: A few more jobs Reply with quote
Whilst so much is still off the car I thought I address the rear shock bump stops and gators. I'd had them a while so it was long over due. All went to plan on the RHS but boy was the old one shot. I did the front a few months back and the bump stops were toast the rear bump stop on the RHS didn't exist , the old one is on the right in the picture Surprised I'll do the LHS tomorrow.
I'd also brought a new power steering cover as mine had a broken lug on it, so while I was working on the RHS it seemed like a good time to change it. I wanted to inspect the drive belt too so I killed two birds with one stone.
If you haven't done this it's not that easy at first.Evil or Very Mad I followed the W/S manual which talks about doing it with the engine out so no help at all Mad
It is really tight and there is just not enough space to slide the cover out. However, if you release the tinware and drop the engine down on the rear engine carrier, support with a jack, you have enough space. Very Happy In fact I found 2 broken lugs and I believe at some time someone had forced the cover to check the belt. If I had pushed harder the two lugs would have broken off I have no doubt about it.
ATB Smile
 Filesize:  135.32 KB
 Viewed:  672 Time(s)
 Filesize:  114.26 KB
 Viewed:  672 Time(s)
