996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayman : 2005- 17
Cayenne : 2003- 7
Macan : 2014- 3
912-914-924-928-944-968 3
basildon993
PostPosted: Sun Mar 19, 2017 10:32 am    Post subject: Cargraphic Air Lift? Reply with quote
So, I had my turbo lowered around 8 months ago using H&R -20mm springs which actually lowered the car 25mm when measured at the arches. And now I need a new front splitter as it has nearly been ground all the way through! I have to park in a multi-storey car park and it is causing a big problem now that the car is so low! As the front splitter is body colour on my car and the replacement will have to be sprayed I don't really want to have to do this once a year!
I'm therefore thinking about getting air lift fitted to the front. Have any of you got this fitted? Is the Cargraphic kit my only option? At what speeds does it operate under? Any help and feedback would be much appreciated as I understand it isn't going to be a cheap option!!!
997.1 Turbo Coupe Manual
ex 993 Carrera 2 Manual
ex 3.2 G50 Carrera Targa Manual
ex Chevrolet Camaro IROC Z Manual
seeforez
PostPosted: Sun Mar 19, 2017 11:27 am    Post subject: Reply with quote
i think they can work upto 30mph, not sure of any other front lift kits out there for 997
Ken White
2008 Porsche 997 Carrera 4S
PostPosted: Sun Mar 19, 2017 12:40 pm    Post subject: Reply with quote
I have a Tech Art hydraulic lift system on my C4S. It was quite a bit more money than the airlift. Tec 9 neat Liverpool fitted it for me.
basildon993
PostPosted: Sun Mar 19, 2017 1:18 pm    Post subject: Reply with quote
Parr do the Cargraphic kit and are pretty close to me.
seeforez
PostPosted: Sun Mar 19, 2017 5:34 pm    Post subject: Reply with quote
Any pictures ken of it up and down ?
Ken White
PostPosted: Sun Mar 19, 2017 5:39 pm    Post subject: Reply with quote
I think if you go on Tech9 website or YouTube, you can find a short video of it going up and down. I think it lifts to a max of 45 mm going by memory.
isysman
PostPosted: Sun Mar 19, 2017 5:41 pm    Post subject: Reply with quote
When my car is lowered in the summer I'm having a TechArt kit fitted. It will be as part of my suspension upgrade It's not automatic in upward direction at least. You have to activate it yourself. I believe it lowers automatically at 30mph
Why not just fit an unpainted front splitter?
911 GT2RS Build
987 Boxster S 3.4
seeforez
PostPosted: Sun Mar 19, 2017 5:42 pm    Post subject: Reply with quote
thanks ill have a look Thumb
basildon993
PostPosted: Sun Mar 19, 2017 6:32 pm    Post subject: Reply with quote
The splitter is nearly worn through to the holes in it! Whether it is painted or not won't stop that. Surprised
isysman
PostPosted: Sun Mar 19, 2017 6:48 pm    Post subject: Reply with quote
I'm not suggesting an unpainted splitter will stop it from being damaged, I'm just saying that even with an axle lift it will still get damaged when you forget to raise it or it hits whilst driving. An unpainted one will be less expensive to replace.
911 GT2RS Build
987 Boxster S 3.4
Winny911
PostPosted: Sun Mar 19, 2017 7:45 pm    Post subject: Reply with quote
I asked Parr about the car graphic one at my last service and they no longer do this.
Anyone got a link for the tech art one?
isysman
PostPosted: Sun Mar 19, 2017 7:47 pm    Post subject: Reply with quote
http://www.techart.de/fileadmin/content/PDF/000991626004.pdf
911 GT2RS Build
987 Boxster S 3.4
basildon993
PostPosted: Sun Mar 19, 2017 7:51 pm    Post subject: Reply with quote
They need to update their website then! Confused
http://www.parr-uk.co.uk/performance/cargraphic-airlift-kit-2wd.html
basildon993
PostPosted: Sun Mar 19, 2017 7:59 pm    Post subject: Reply with quote
Link to the Cargraphic site.
http://www.cargraphicts.com/en/products/suspensions/airlift/for-porsche/detailed-information/
