997 : 2004- 68
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Classic : 1950-1965 1
Boxster : 1997- 15
Cayenne : 2003- 9
912-914-924-928-944-968 4
stonerose
PostPosted: Sat Mar 18, 2017 5:59 pm    Post subject: Help - engine starts then cuts out Reply with quote
Hi - a couple of times today I started my 996 c2 3.6 only for it to then cut out about a second later. Both times were after the car had been driven for about an hour then left for half an hour. Any ideas?
Many thanks in advance
alex yates
PostPosted: Sat Mar 18, 2017 6:03 pm    Post subject: Reply with quote
Mine sometimes does it when the tickover is dodgy. It's intermittent on mine and can't find anything wrong with it. No CEL/codes or anything.
Right pain in the back end.
Demort
Estoril
PostPosted: Sat Mar 18, 2017 6:36 pm    Post subject: Reply with quote
If your car is cable throttle then this might help ..
http://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/28-FUEL-Throttle_Body_Cleaning/28-FUEL-Throttle_Body_Cleaning.htm
Sounds like something is getting hot though , possible crank sensor , fuel pump relay .. afraid i could mention many things .
EDIT ..
Just to say if its cable then you have an idle valve which might be faulty .
At an Indy these days !
Palladium
Watkins Glen
PostPosted: Sat Mar 18, 2017 6:37 pm    Post subject: Reply with quote
earth strap
stonerose
PostPosted: Sat Mar 18, 2017 6:48 pm    Post subject: Reply with quote
Car is tiptronic by the way
Harv
PostPosted: Sun Mar 19, 2017 7:20 am    Post subject: Reply with quote
Is the cutout a complete stop like the ignition is being turned off or is it more of a splutter?
As Demort says it could be lots of things but one thing that springs to mind is possibly a failing fuel pump but crank sensor would be my first item to check. Need to have someone with diagnostic software have a look at it really
Hope you get it sorted
stonerose
PostPosted: Sun Mar 19, 2017 9:14 am    Post subject: Reply with quote
Not a splutter. Just idles for sec then dies
MMT
PostPosted: Sun Mar 19, 2017 9:31 pm    Post subject: Reply with quote
Aren't all 3.6 ethrottle?
