996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
decgraham
PostPosted: Fri Mar 17, 2017 5:54 pm    Post subject: Camshaft covers off Reply with quote
Hi All,
Final job to do after the timing chain covers was the camshaft covers while everything was off. On the RHS two of the bolts would not come out and although I used a good quality allen key with a impact driver they just would not budge. I then drilled the head out with a 6mm bit and forced in an oversized allen key and that did the job. Tried the same approach on the second one but it wouldn't come out. I then drilled it a bit more with the 6mm bit and sheared the head off, I was then able to remove the cover and then get a pair of mole grips on to the remainder of the bolt, all sorted. On the LHS only one bolt required drilling and using the oversized allen key did the job. I now have both covers off awaiting the arrival of new gaskets and 22 new bolts. I'm having a well earnd rest over the weekend as I now ache all over Laughing Crawling under a car is a young mans job Laughing
I now only have the PU to fit along with the lights and the mufflers Cool
A few pics for info.
ATB Smile
 Filesize:  111.88 KB
 Viewed:  1468 Time(s)
 Filesize:  117.33 KB
 Filesize:  136.63 KB
 Filesize:  149.22 KB
 Filesize:  156.86 KB
 Filesize:  136.45 KB
ChrisT70
PostPosted: Fri Mar 17, 2017 7:10 pm    Post subject: Reply with quote
Persevering rather than panic! Well done that man!
Afraid of dipping a toe- beware Sharks
Ex 993S now sold
wilsonny
PostPosted: Sat Mar 18, 2017 8:34 am    Post subject: Reply with quote
a few tense moments there I'll bet. Step back with that satisfied feeling that you've not broken anything !
Make sure you follow the tightening order (inward out).
1996 C2 manual
decgraham
PostPosted: Sat Mar 18, 2017 11:33 am    Post subject: Reply with quote
Yes some very tense moments but the bolts drilled out very easily as they are made from cheese Laughing
Well thanks for that wilsonny, I would have started top left hand corner and then gone diagonal from one end to the other as you would tighten a cylinder head. May I ask where it says to start from the middle?
ATB Smile
wilsonny
PostPosted: Sat Mar 18, 2017 11:52 am    Post subject: Reply with quote
bentley service manual (page 15b-15 if you have it). torque to 10nm...i used a bicycle torque wrench (small hand held thing).
it takes loads of cycles around the tightening order to get then all right, but ive not had any drips following this method. i filed my Alan heads with copper grease afterwards to try to control corrosion.
1996 C2 manual
decgraham
PostPosted: Sun Mar 19, 2017 6:48 pm    Post subject: Reply with quote
Thanks again much appreciated Thumb
ATB Smile
Jet Jock
PostPosted: Sun Mar 19, 2017 9:18 pm    Post subject: Reply with quote
Sterling work Dec. Thanks for posting up the pics.
993 C2, RSR's, Cargraphic 100 Cell Cat, Turbo Twist Hollows, Brembo Big Reds Turbo Brakes, Big Ovals, Wayne Schofield Remap, KW Supersport set up by Chris Franklin, RS engine and transmission mounts, Fabspeed induction kit, HID conversion...
Cameltoe & Heel
PostPosted: Mon Mar 20, 2017 8:39 am    Post subject: Reply with quote
Yeh super work, something I have to attack soon but should be somewhat easier as my engine is out, like the way you approached the seized bolts, good man.
Trev
Kryton
PostPosted: Mon Mar 20, 2017 9:01 am    Post subject: Re: Camshaft covers off Reply with quote
decgraham wrote:
Hi All,
Yes but at least you'll be warm in Spain Smile
991.2 GT3, full Club Sport pack
2Lt 718 Cayman (weekday drive)
