Hi all! Basically car failed mot on emisions as per previous post, had plugged in today and think I'm right in thinking the following readings are the lambda ones (correct me if I'm wrong)
My car only has pre cat lambda sensors no post cat ones so seems to be 2 readings for each bank which is a little confusing but either way do these results confirm coolent temp fine and maf fine but lambda off and if so which lambda....? Already had 2 three years ago so surely both aren't shot again and which side of the car manifold is bank one....?
