Litronic headlights 1999
MMT
18 May 2011
166
When these are removed/fitted, do they push in and locate the electrical connection the same as standard headlights or is there a cable for the self levelling that needs plugging in separately?
Thanks.
Same as standard - one socket at the end :thumb:
Just for reference mate, there is another plug that needs connecting. My self levelling wasn't working so I asked my mechanic to check it all out. Anyway, yesterday I found this on YouTube which shows both the fixed socket for the headlight to push into and another cable as well.
So I showed the mechanic this and within the hour mine was fixed. Turns out for some reason this cable wasn't connected on both headlights and was tucked out of the way. As soon as they were plugged in everything is working as it should.
https://youtu.be/7barCfAmp1A
Ah. mine's a gen 2 and doesn't have that extra cable :thumb:
That's certainly what's in the 996.2, but i found that nearly all the sites are wrong - the correct information is in the owner's manual.
Hmm, I've not checked my owners manual as it's for a 1998 and I thought that predates the Litronics, but of course having a look would have been logical.
Ummm. no. lol
At least, mine certainly don't!
Before you spend the cash, consider the Lunex D2S Headlight Replacement Bulb from amazon. £23 a pair and look identical to the Osram.
for £23 a pair (Osrams are £40 each) I think they're worth a punt when mine need replacing.
Sounds like I need to pull the headlights and take a good look at the connectors. A bit of googling shows that this is a common problem for the Litronic lights.
Demort- is there an approved method of tackling this?
124,589
1,441,841
49,020
cooper9000
