997 : 2004- 64
996 : 1997-2005 34
964 : 1989-1993 1
Cayman : 2005- 20
C2 YYY
PostPosted: Thu Mar 09, 2017 10:17 pm    Post subject: Rear wiper delete Reply with quote
I am fed up with the rear wiper spoiling the lines of the car so have decided to remove it.
I remember seeing something about a kit being available to seal with rear screen, but cannot find any more info.
Any clues and tips i should know?
Many thanks Andy.
1990 964 C2 (manual) - a bit "Ruf"ed up
PostPosted: Thu Mar 09, 2017 10:24 pm    Post subject: Reply with quote
I thought as an alternative to a new rear screen you only had the Bung option Dont know
You then need to have the rear shelf re-covered, or find a suitable material to slot in the gap where the drive shaft came through.
The game's afoot. It's time to put a bit of (Colini) stick about......964/993 wanted. Cash waiting. No dreamers
M
PostPosted: Sat Mar 11, 2017 7:38 pm    Post subject: Reply with quote
Hi Andy
I presume you're talking about the bung route? I did a wiper delete but went for the bung option... I'd only just had a new rear screen fitted with a hole when I had a full glass out repaint. (Some of the heater elements of the original weren't working)
I know you can get plain and heated rear screens without the hole.
I did take out the rear parcel shelf (stored away safely!) and I had a local guy make up a posh foam backed RS style carpet version.
I kept all the original cables, cable tied these up neatly and sealed the connectors in plastic bags.
Ping me a PM if you'd like some more info.
Mike
964 C2 Coupe Manual
997 C4S Coupe Manual
930 Turbo (Sold years ago for £21500 - Aaaargh!)
 Filesize:  883.43 KB
 Viewed:  3531 Time(s)
C2 YYY
PostPosted: Sat Mar 11, 2017 9:28 pm    Post subject: Reply with quote
Excellent responses chaps. I am also planning on the "bung" method, certainly until for the time being.
I will get the old girl out tomorrow and will investigate how far I want to go with it. I was sort of hoping I could simply remove the wiper and motor and the job would be a good one. Alas it does not seem quite that easy. No surprise there.
Many thanks for the offer Mike, I might most likely be back in touch.
M
PostPosted: Sat Mar 11, 2017 9:47 pm    Post subject: Reply with quote
No prob.Thumb
It is easy but you will be left with an unused tube or if you remove the section (that slides in to the parcel shelf) a slot that in my opinion will look a bit odd.
I'm more than happy to pull out the new 'shelf' and take a pic if you want.
I searched all this out on the forums etc before I got out my socket set!!
Oh, before I forget... the screw thread in the bung I bought had to be trimmed to fit to make it sit tight against the glass, I also used some silicone to make sure it didn't leak too.
Mike
964 C2 Coupe Manual
ras62
PostPosted: Sun Mar 12, 2017 9:58 am    Post subject: Reply with quote
Porsche do a window bung, its annodised alloy and a 944 part from the club sport I believe.
