Hi all,
So, after purchasing a lovely set of Top Gear Valvetronic exhausts that have the wireless remote control, I was wondering if anyone knows or has the knowledge on how i could go about connecting it to an OE switch ??? There is no wiring behind the dash for said switch.
I have seen the post on here where someone has wired up a 997 using a relay, resistors and a bit of circuit board etc. but on his car there is wiring for the switch set so was just a case of adding the feed wires for the PSE to the block, but with the 996 i'd have to wire the full switch i think... Not sure how many connections there are on the back of the switch.
Any "idiot proof guides" to do this this kicking around that i could attempt :thumbs:
Craig
Craig
