996 : 1997-2005 42
993 : 1993-1998 9
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayman : 2005- 17
Cayenne : 2003- 7
isysman
PostPosted: Wed Mar 08, 2017 4:15 pm    Post subject: Need help with Cayenne S Hybrid blind issue Reply with quote
Hi guys,
I wonder if anyone can help me and a frustrated billionaire?? Very Happy
I'm in the Bahamas right now and my boss is having issues with his Cayenne. There is I'm told no dealer here in Bahamas and the garage who is not a specialist wants $1,000 per window to repair it. And I'm not sure they even know what they are doing certainly with a Porsche.
So I have made a short video and you can see the blind is going mental. It happens on both rear windows when you operate the electric window button. The windows do not move at all in either direction. (the captain said it looks like the car is jerking itself off!)
I've told the chief engineer that we should order a Durametric cable which we are going to do so hopefully I will be able to diagnose this issue once connected. We also have the horn beep twice when I lock the car so there is another underlying issue going on as well.
I was going to disconnect the battery and do the learning process but its a Hybrid and I didn't know what might happen if I did that. I pulled the fuses instead but as soon as I pulled the button it started over again.
Any help would be appreciated.
Open Youtube Page
911 GT2RS Build
987 Boxster S 3.4
PostPosted: Wed Mar 08, 2017 4:48 pm    Post subject: Reply with quote
I'd disconnect the battery to see if that solves it as an alternative to clearing out the fault codes via durametric. The problem of course is the battery is under the seat somewhere what It shouldn't affect the hybrid as that is I believe a separate battery to the one that controls auxilliaries (ie normal car battery)
My Cayenne had some 'electrical' issues Rolling Eyes Sometimes the comfort entry wouldn't return the seat to the memory position when I got back in. I kept my Bay City Roller platforms handy in case the memory button didn't work to take the seat back to where I left it Grin Never did get to the bottom of it frustrated
ragpicker
Paul Ricard
PostPosted: Wed Mar 08, 2017 5:14 pm    Post subject: Reply with quote
I think the captains description is pretty accurate! Its the noise that goes with it...
Reminds me of staying in a youth hostel in the 1980s.........
Embarassed
996 turbo - slightly modified....
isysman
PostPosted: Wed Mar 08, 2017 5:40 pm    Post subject: Reply with quote
So the battery is under the rear seat?
911 GT2RS Build
987 Boxster S 3.4
isysman
PostPosted: Wed Mar 08, 2017 6:31 pm    Post subject: Reply with quote
Don't see a battery under the seat. What year was yours, this is a 2013 model.
911 GT2RS Build
987 Boxster S 3.4
DynoMike
2003 Porsche 996 Turbo
PostPosted: Wed Mar 08, 2017 7:48 pm    Post subject: Reply with quote
Embarassed
Short stroke, Rags? Grin
2003 996 Turbo
Previous toy 1974 Mini 1000
DynoMike
PostPosted: Wed Mar 08, 2017 7:50 pm    Post subject: Reply with quote
On the earlier 957 gen cars, I think the battery is under the passenger front seat, or drivers side if a left hooker. I personally would tread very carefully there....
2003 996 Turbo
isysman
PostPosted: Wed Mar 08, 2017 9:51 pm    Post subject: Reply with quote
Yeah I don't really want to disconnect the battery. I'm trying to get this Durametric cable shipped over.
911 GT2RS Build
987 Boxster S 3.4
isysman
PostPosted: Thu Mar 09, 2017 3:38 am    Post subject: Reply with quote
Ordered the Durametric cable today, so we will see what happens when I get it. I did ask Alan Dyde at Porsche Wilmslow and he actually came back to me.
"sorry but cannot think of anything you can do other that try to get window
up-down on a full cycle from front or window switch if it allows you to.
otherwise requires a calibration with system tester."
Hope it's not the last bit. I don't think I could do that with the cable I ordered. Car would have to be shipped to US!
911 GT2RS Build
987 Boxster S 3.4
PostPosted: Thu Mar 09, 2017 8:48 am    Post subject: Reply with quote
Forget the battery option as you have to take the front passenger seat out just to get to it nooo In the 958 they are still under the floor however charging points are fortunately in the engine bay.
isysman
PostPosted: Thu Mar 09, 2017 3:06 pm    Post subject: Reply with quote
Yeah I saw the charging points, but I wanted to disconnect the battery to hopefully be able to reset the windows. I have Wilmslow Porsche sending me the workshop manual for it.
911 GT2RS Build
987 Boxster S 3.4
Captain Lockheed
PostPosted: Thu Mar 09, 2017 3:56 pm    Post subject: Reply with quote
Window controller (some people call it a regulator) fault.
I can't see the you tube video at work, i will try and find time tonight.
I am available to fly out with my PIWIS Very Happy
997.1 C2S Tip 2005
Saving for a 993.
isysman
PostPosted: Thu Mar 09, 2017 4:15 pm    Post subject: Reply with quote
Thanks for the info. That's very generous of you!
911 GT2RS Build
987 Boxster S 3.4
Demort
Estoril
PostPosted: Sat Mar 11, 2017 6:47 pm    Post subject: Reply with quote
It looks like theres some sort of rollback protection that the blind is stuck on , it needs to be closed before the window will work .
Im not aware of a manual way of moveing them , check the owners manual and also try turning on or off rear child lock on the doors and operating the windows from the divers door switches .
I think youll going to need a piwis or something similar though to test or calibrate them .
Disconnecting the battery probably wont help as all it will do is cause the windows to loose there stored up and down positions .. one touch wont work in other words .
Battery is under the front passenger seat .. obviously dont touch anything on the battery in the rear .. thats the hybrid one and has nothing to do with the vehicle electrics .
At an Indy these days !
isysman
PostPosted: Sat Mar 11, 2017 7:08 pm    Post subject: Reply with quote
Thanks Dermot. Yeah I've tried the child lock thing. It's the same from the front. Both windows do it as well so it seems odd that both mechanical motors could fail. I thought resetting the windows via a battery disconnect might allow them to be calibrated. At least with the Durametric I'll be able to get error codes.
Boss doesn't want them fixed, he wants them disabled but the ability to open the windows.
911 GT2RS Build
987 Boxster S 3.4
Demort
Estoril
PostPosted: Sat Mar 11, 2017 7:35 pm    Post subject: Reply with quote
Im afraid its not a fault ive come across before .. both doors is odd though and im guessing theres some sort of calibration on a tester .. windows wont work unless the blind is closed ie not covering the window so unless it can be closed then the windows will not work as far as im aware.
I had a look through the owners manual and there doesnt seem to be any manual way of moving them .. not at work for a while so cant check anything for you , sorry .
Post anything you can see when you get the durametric on it please .
