997 : 2004- 74
996 : 1997-2005 42
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Wed Mar 08, 2017 12:29 pm    Post subject: Claying alternatives... Reply with quote
I've never been especially fond of claying, is it always necessary?
Not clayed mine for 18 months, was wondering if some iron fallout remover and tar remover before snowfoam and washing, then my usual Zymol HD cleanse and wax will be sufficient.
Or any other less faffy alternatives to claying?
arry
PostPosted: Wed Mar 08, 2017 12:32 pm    Post subject: Reply with quote
Still claying as such, but easier:
http://www.slimsdetailing.co.uk/polishing/clay-bars-mitts-lube/dodo-juice-sponge-clay-pad-fine.html
I use one and find it a bad boy. Less faff, good results.
2001 Lapis Blue 996 C2 Manual
2012 Orange KTM 990 SMT
2016 Marsh Grey Royal Enfield Bullet 500
michelin
2006 Porsche 997 Carrera 2
PostPosted: Wed Mar 08, 2017 12:37 pm    Post subject: Reply with quote
Best way firstly is to use a product such as 'Iron X'.
It basically breaks down all surface contaminents, turns them purple and then you're ready to hose them off. It does smell by the way but is brilliant!
Try it on your wheels first and watch them turn purple instantly.
Once decom'd I then lightly clay but you find the previous step rids the paint of all the nasties.
Ford Fiesta XR2 MKII, Ford Escort RS Turbo Series 2, BMW E36 318iS Coupe, Audi A4 B7 2.0T FSI S-Line, Porsche 911 997. Present: Porsche 981 S Fully Loaded, beautiful.
stucart
PostPosted: Wed Mar 08, 2017 12:38 pm    Post subject: Reply with quote
Garcia G3 Formula Clay mitt gets my vote, got mine from Halfords, makes the job easy and was pleased with results. Sure its been discussed before on here, do a search.
997 C4S Tip-S, 2007, Silver/Red Leather, PSE, Sports Chrono, Turbo wheels.
KJD
PostPosted: Wed Mar 08, 2017 2:26 pm    Post subject: Reply with quote
IMO claying is a vital stage in preparation for polishing if you want to achieve the best possible result.
It's not a job I mind doing and once it's been done fairly easy to go over your car to freshen the paint work say once a year.
Clay clothes and mitts are now used quite widely to speed up the process but I like to use a bar and work on a panel at a time.
I'm currently working through a multi stage full detail. Iron X de-tar and clay completed, about to start a 2 stage machine polish before a final coat of Swissvax Thumb
Arctic Silver 997 Manual Carrera 2s
michelin
PostPosted: Wed Mar 08, 2017 2:28 pm    Post subject: Reply with quote
Will Iron X not rid Tar?
If not, which de tar fluid do you use?
KJD
PostPosted: Wed Mar 08, 2017 2:33 pm    Post subject: Reply with quote
Iron x is fall out remover and won't remove tar.
I always use Tardis tar remover.
Both products do roughly the same function but on different contaminants.
michelin
PostPosted: Wed Mar 08, 2017 2:49 pm    Post subject: Reply with quote
Gottans
PostPosted: Wed Mar 08, 2017 9:45 pm    Post subject: Reply with quote
I used to use valet-pro dragons breath on the wheels but it seems to coat the steel brake discs and takes qiuite of braking to remove it and yes it does smell like nothing else you've ever sniffed. Now use the Bilberry wheel cleaner, very pleased with it.
G3 clay mitt is very easy to use, plenty of lubricant and it does a good job.. If you feel the need to use a clay bar, the BH ones only need water as a lubricant.
Chillout
PostPosted: Thu Mar 09, 2017 7:54 am    Post subject: Reply with quote
CarPro Trix does both, iron and tar, works ace for me.
58 plate Cayman S in Carrera white with Carrera red interior
Chillout
PostPosted: Thu Mar 09, 2017 8:01 am    Post subject: Reply with quote
Ursa911
PostPosted: Thu Mar 09, 2017 9:11 am    Post subject: Reply with quote
Agree Yup what Stu said
"If you see the tree you are driving in to, you have under steered. If you only hear it, you have over steered." - Walter Röhrl
2004 996.2 Manual C4S Cab Arctic Silver - Ursa911
Outliar
PostPosted: Thu Mar 09, 2017 9:32 am    Post subject: Reply with quote
Excited to try Iron X and Tardis, as I was just thinking about getting round to the annual polish...
What is "fall out"?
1996 993 C4
Ducati 996
Chillout
PostPosted: Thu Mar 09, 2017 1:44 pm    Post subject: Reply with quote
Sorry about the double post - not sure how that happened.
Getting all the stuff ready for my spring blitz too:
Trix
Clay
Poorboys SSR2
Poorboys Polish
Poorboys White diamond
Dodojuice Diamond white
In that order.
Yes it's a white car.
Robertb
PostPosted: Thu Mar 09, 2017 1:57 pm    Post subject: Reply with quote
Cheers guys, I ordered some Bilt Hamber Korrosol iron remover, and some G Techniq tar remover.
The paint feels not too bad, so hopefully after decontaminating, claying shouldn't be too tedious as the paint feels mostly good...
KJD
PostPosted: Tue Mar 14, 2017 10:58 pm    Post subject: Reply with quote
What is "fall out"?
It's just all the debris and metal particles in the atmosphere that sticks to the body work .
CarreraMonkey
2007 Porsche 997 Carrera 4S
PostPosted: Sun Mar 26, 2017 8:32 pm    Post subject: Reply with quote
Trix for me. Probably not as effective as separate iron and tar remover but it works for me and saves a little bit of time.
I used to use a clay bar but now use a clay mitt. I just find it less faff to be honest.
And I always remove the iron and tar first, before claying.
Laters Taters!
michelin
PostPosted: Mon Mar 27, 2017 7:53 am    Post subject: Reply with quote
Clay mitt recommendations?
CarreraMonkey
PostPosted: Mon Mar 27, 2017 12:48 pm    Post subject: Reply with quote
Farecla G3 clay mitt.
http://www.halfords.com/motoring/car-cleaning/clay-bars-detailing-products/farecla-g3-body-prep-clay-mitt?cm_mmc=Google+PLA-_-Car+Cleaning-_-Clay+Bars+&+Detailing+Products-_-660104&_$ja=tsid:60494%7Ccgn:GoogleShopping%7Ckw:660104&istCompanyId=b8708c57-7a02-4cf6-b2c0-dc36b54a327e&istItemId=xmwwxmili&istBid=tztw&_$ja=tsid:35522|cid:344535484|agid:25437357604|tid:pla-235312772644|crid:89797548604|nw:g|rnd:5184616578251872278|dvc:c|adp:1o1&gclid=CJ6pmI7c9tICFQMW0wodX7ICvw
Laters Taters!
michelin
PostPosted: Mon Mar 27, 2017 1:06 pm    Post subject: Reply with quote
Thank you sir Thumb
