Phil 997 said:Come on J , what you planning now that needs that part removed
opcorn: opcorn: opcorn:
-- 997 -- said:Phil 997 said:Come on J , what you planning now that needs that part removed
Cheers eliot_holder, ill do it at the weekend!!
Hahhaaaaa, ok its that i was under the steering undertray getting a couple wires soldered to the clutch switch that you have to press to start car, so am planning to fit a small push switch as a backup to start car rather than pressing the clutch to start!! And as it started to rain on and off i decided to put the car in the garage, anyway the contact switch works well when pressed and turn the key to start but reason why i ask about the undertray dismantle is that i wanna take off and cut out a small hole to fit the push switch etc !!,
J
Phil 997 said:-- 997 -- said:Phil 997 said:Come on J , what you planning now that needs that part removed
J
Ah that's a very interesting little mod your planning not heard of anyone doing that before . Good luck with it mate :thumb:
