996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
coopertrooper2001
PostPosted: Tue Feb 28, 2017 12:33 pm    Post subject: Traffic film/condensation Reply with quote
My car is steaming up periodically i.e. its been fine for a few weeks but has started again yesterday and today.
It starts like traffic film, mainly on the windscreen which I can wipe off with a cloth, but it comes back. Then after a little while turns to condensation.
I have had the air con checked and all is apparently OK, but it struggles to clear the glass even on mega hot and directed to the screen and side windows, or even just on the screen.
Re-circ is off and ice symbol on. I can hear pump kicking in and revs drop accordingly.
I have cleared out the bulkhead drains, but there was no standing water.
I do not have a sunroof or soft top.
I am assuming a leak somewhere. I have felt the bottom of the door cards - all dry.
I am guessing next step is to lift the carpets. Hoping for some advice here as I tried driver and passenger foot wells. Found the carpets glued down. I did pull away a little on the sidewall, but could only get my hand part way under. It did however feel dry.
Could it be the air con drain hose? Should I see a puddle, even in colder weather?
Any advice appreciated, its ruining my daily drive and making me want to see an otherwise perfect motor.
maldren
PostPosted: Tue Feb 28, 2017 12:42 pm    Post subject: Reply with quote
Probably just the time of year and the damp weather. My car does it too but so do my Mondeo and my wife's Celica. Keeping them in a dry garage would probably help but mine's full!
A good run with the aircon will help dry things out. Opening the door or windows to get rid of moist damp air after using the car also helps a lot.
Mike
Harv
PostPosted: Tue Feb 28, 2017 2:35 pm    Post subject: Reply with quote
Couple of things you can check:
1. When was pollen filter last changed and is it dry, clean and in good nick?
2. Is aircon system gassed?
3. Has the AC drier canister been changed recently?
Normally one or all of the above is seriously neglected and this dosent help with seasonal misting up.
coopertrooper2001
PostPosted: Tue Feb 28, 2017 5:42 pm    Post subject: stuff to check Reply with quote
Is the pollen filter the one directly under the passenger side windscreen? If so I took this out and checked - clean and dry.
System re-gassed last week, checked again and is holding the right amount of gas.
Receiver dryer never changed as far as I am aware.
Are water leaks common? I read about ICE installs creating bulk head breaches, but I have a standard setup.
Keen to rule out a water build up somewhere. Have had this on cars in the past, but the misting is nowhere near this level, yet.
911tom
PostPosted: Tue Feb 28, 2017 6:51 pm    Post subject: Reply with quote
You don't use one of those e-cigarettes do you? One of my clients was telling me the other day he spent a fortune at the garage trying to establish why his car kept misting up. Turned out to be the e cig. It was leaving a vapour on the windows which was causing the car to keep misting up. As soon as he cleaned all the glass and stopped vaping in car the problem never came back.
996 Turbo - Link to my 3.8L turbo build thread
2011 Cayenne
2009 Ariel Atom 3 Supercharged
350Bhp astra van for work Surprised
911tom
PostPosted: Tue Feb 28, 2017 6:52 pm    Post subject: Reply with quote
Not sure how changing the dryer would help the situation?
2011 Cayenne
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Feb 28, 2017 7:10 pm    Post subject: Reply with quote
It sounds like a water ingress problem to me. I would lift the carpets front and rear to check.
mzmini
PostPosted: Tue Feb 28, 2017 7:43 pm    Post subject: Reply with quote
Coopertrooper 2001 do you have a rear wiper fitted ? I too suffered with condensation, water was working its way in through the rear wiper arm shaft grommet a smear of silicon has cured the problem
997 3.8 C2S
987 Boxster 3.4S
Disco 3
2012 VW Polo
1964 1071 Cooper S
1964 1071 Cooper S 1991 Pirelli Classic winner
1971 1275 Cooper S as new time warp
1996 106 Peugeot van (pride of the fleet)
cheshire911
Estoril
PostPosted: Tue Feb 28, 2017 9:51 pm    Post subject: Reply with quote
Water leak possible culprit. Check carpet in both front footwells and rear footwells.
With the recent cold weather the AC cuts out (I think at temp below 4C - but check in the manual).
996 2002 X50 Turbo Manual
coopertrooper2001
PostPosted: Wed Mar 01, 2017 9:34 pm    Post subject: Responses Reply with quote
Thanks for the thoughts all.
1. No smoker
2. Yes I have a rear wiper. WIll check that out. Rear shelf area feels dry at the top level.
Keen to lift carpets and inspect underneath. Rears are dry, but cant find an easy way to lift the fronts - any advice?
Pip1968
PostPosted: Wed Mar 01, 2017 10:58 pm    Post subject: Reply with quote
Last time I had something like that it turned out to be the heater matrix but it was in a BMW. Starts with a windscreen that does not clear and keeps misting up and progresses to a wet carpet in the footwell.
Getting your hand under the carpet just means you will spot the problem earlier but hand on top will do. Once it gets wet it's wet.
Best of luck
Pip
coopertrooper2001
PostPosted: Mon Mar 06, 2017 11:30 am    Post subject: Further investigation Reply with quote
This weekend I had the carpets up in both the front and rear foot wells, checked the door cars and stripped out the entire area under the rear window.
All dry as a bone.
Checked the pollen filter. Bone dry and reasonably new (service was June 2016).
Cleaned the windows again yesterday and then drove in today and the film/light condensation started up again within 5 miles.
Can anyone direct me to the location of the air con drain tube and the heater matrix?
I will get the aircon system checked again this week to detmine if it is not working correctly and therefore not venting the cabin properly.
Reasonably happy the car appears dry, but this is really starting to spoil my driving experience. Any further thoughts welcomed!!!
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Mar 06, 2017 1:57 pm    Post subject: Reply with quote
Is the recirculation switch functioning OK?
MisterCorn
PostPosted: Mon Mar 06, 2017 2:14 pm    Post subject: Reply with quote
It really sounds to me like water is getting in there somewhere. I have old cars with no air con and even in the winter they are nothing like as bad as what you describe. I don't think a fault air con would cause these issues.
coopertrooper2001
PostPosted: Tue Mar 07, 2017 12:14 pm    Post subject: Update Reply with quote
Good shout on the re-circ button, hadn't thought to check that. Appears to work OK in that fan speed increases when turned on and decreases when turned off.
I am going to start calling it a film rather than condensation. Its as if the screen is still dirty and any moisture is clinging to it. Cleaned the screen yesterday morning (3rd time in as many weeks) and after half an hour of driving the film was back. It creates like a smokey effect on the inside of the glass.
Even with the blower on full, it does not clear. I have to wipe it off...
I am confident its not a water leak as water will generally find the lowest point and collect there and everything was dry, even higher up points!
I also checked the door drains and they were clear.
Robertb
PostPosted: Tue Mar 07, 2017 1:49 pm    Post subject: Reply with quote
Most odd... does the film clear by itself if left long enough, or does it remain til wiped off?
If left in the sun (fat chance) does it mist up?
coopertrooper2001
PostPosted: Tue Mar 07, 2017 3:32 pm    Post subject: film Reply with quote
No amount of heat, aircon etc will clear the film. It has to be wiped off.
Car does not mist up at all when left overnight/during the day in sun or shade - hence I don't believe there is moisture in the car.
coopertrooper2001
PostPosted: Fri Mar 17, 2017 12:57 pm    Post subject: Still struggling with this Reply with quote
I am still struggling with this issue. I am convinced it is not condensation. Something is contaminating the inside of my windows and normal levels of condensation are then sticking to the contamination.
With a few nice warm days this week I have zero condensation, yet the film on my window continues to increase each day.
Its almost like grease on the window. It is becoming harder and harder to wipe off.
I feel the aircon system is working well as on one of the warm days the airflow was ice cold.
Any ideas? I am at a bit of a loss where to take it for further investigation.
Where abouts is the heater matrix? Is it below/behind the gear stick area?
I am wondering if this could be leaking and emitting the contaminant out in a fine mist from the air vents. Probably a crazy theory.
edge
PostPosted: Fri Mar 17, 2017 2:13 pm    Post subject: Reply with quote
What are you cleaning the window with ? Does the film appear on all the windows?
Sold 2004 Boxster S
Sold 2006 997S
Sold 2008 GT3
Sold 2009 Boxster S
Sold Red 2013 981 S
997 Gen2 Turbo
coopertrooper2001
PostPosted: Fri Mar 17, 2017 3:11 pm    Post subject: cleaners Reply with quote
Have tried various cleaners. I wondered if AutoGlym Fast glass was the initial cause, but have since cleaned with meths to strip away the grease. Its fine for a few days then comes back!
Have also tried Mr Muscle glass cleaner and even a karcher window vac.
Have just bought some AutoGlym Glass polish to give that a try.
Appears on all windows except the rear quarters. I have cleaned them all, each time.
