997 : 2004- 82
996 : 1997-2005 47
Boxster : 1997- 15
Cayman : 2005- 15
Georgestamos
PostPosted: Fri Jul 14, 2017 9:32 am    Post subject: 964 LED Headlamps Reply with quote
Would be interested to know what you guys think about these. I'm testing the water with a bulk order to see what's possible.
New LED headlamp designs launching Stateside with a new website shortly but you can beat the queue by placing orders here first if you like what you see.
These are not the cheap versions that use Chinese motorcycle lenses. These are 'plug & play' fittings of the highest quality. This design engineer has sourced military grade wiring, designing his own moulds for the lenses, custom making the shrouds and designing the circuitry. These units use Osram nightbreaker bulbs and Japanese DENSO ballasts.
There are two versions available, the Phoenix and the Raven, both of which can also integrate a turn signal / indicator lens. These are comparable with European, UK & USA cars.
Included with each set is a 5 year warranty that covers construction and most of the Electronics. The German bulbs come with a 2 year warranty.
Check out the PDFs. They are not cheap at around $2,000 but you do buy quality. PM me for more details if interested.
1990 964 C2 Targa in black
 Filesize:  294.29 KB
 Viewed:  2427 Time(s)
 Filesize:  361.14 KB
 Filesize:  1017.5 KB
