996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
Thefinn
PostPosted: Sun Feb 26, 2017 11:39 am    Post subject: Reply with quote
991 lip on 997
997.1 C4S CAB
porsche_911_552997_spoiler_f9d3cd158fd12cca4874fbb334b65f228ac36271_325edfdc6f6610c477c3d7174811cef0f2b47664.jpg
 Filesize:  198.57 KB
 Viewed:  1205 Time(s)
PostPosted: Sun Feb 26, 2017 5:04 pm    Post subject: Reply with quote
Thefinn wrote:
Check out this post this has quite a few of the options out there with pictures, I quite like the one off the 991 fitted to the 997.2
http://www.6speedonline.com/forums/997/252403-best-front-lips-997-2-s-4.html#PhotoSwipe1488108842737
PLUS 1 for the 991 modified for the 997.2 looks good and is a Porsche part .
PostPosted: Sun Feb 26, 2017 5:14 pm    Post subject: Reply with quote
Finn, that rinspeed is very nice, why did you need to widen it was it not for the 997.1 as the front is the same on the wide body to the narrow body. If your not lowered much but want a nice subtle splitter that will do the job nicely in fibreglass. Thumb
monster
PostPosted: Sun Feb 26, 2017 5:40 pm    Post subject: Reply with quote
I had the Maxton design lip on mine for a while until I ripped it off at high speed - looked a bit 'Max Power' but I kinda liked it Cool
I bought the 991 lip pictured above about a fortnight ago after reading the 6speed thread, its still on the top of my wardrobe waiting to be fitted though - I'll post pics up when its on!
PostPosted: Sun Feb 26, 2017 5:43 pm    Post subject: Reply with quote
Looking forward to seeing it up close monster, Looks like a very good option for the gen2 front end Thumb will it be fitted by the curry night
Thefinn
PostPosted: Sun Feb 26, 2017 8:56 pm    Post subject: Reply with quote
It was wide enough just one end didn't quite get round the return on the bumper as it turns into the wheel arch. I had to cut it with a Dremel but only the top two thirds to make it slightly longer at the top. I am making it sound worse than it was, other than that the fit was very good. I should have taken a picture but I was on a deadline so just wanted to get it done as I had to put the transmission back together after trying to fit powerflex inserts that don't fit my car. Plus also fit new rss engine mounts that Mrs Finn got me for Christmas that finally turned up this week after 2.5 months wait.
997.1 C4S CAB
PostPosted: Sun Feb 26, 2017 10:19 pm    Post subject: Reply with quote
Ah that explains clearer what you meant, let us know haw you like the RSS mounts , are you going to try the function first transmission mount inserts
http://www.function-first.com/products/engine-trans/trans-mount-insert
Thefinn
PostPosted: Sun Feb 26, 2017 10:53 pm    Post subject: Reply with quote
I have only driven it a bit since fitting them on Friday but so far the mounts are great it's all just a bit tighter now none of that feel of the engine shaking when u press the throttle, especially when stationary. Noise has risen a little but only in first and second when you lift off a slow speeds it sounds a little like close cut gears but nowhere near as loud I quite like it. My gear shift has improved as well so I think I will leave it there rather than going for the inserts as well, especially now I have seen my trans mount it's nearly solid anyway an after Floydsolo post about the FF ones when he has the same mount as me I think I will leave alone. I might change my mind later down the line but I will try with just the mounts for a while and see how I go.
997.1 C4S CAB
PostPosted: Sun Feb 26, 2017 10:56 pm    Post subject: Reply with quote
Good to hear , I tried to describe it as feeling GT3 ish a bit more mechanical but in a good way and very flat on corners . Thumb Thumb
monster
PostPosted: Mon Feb 27, 2017 12:59 am    Post subject: Reply with quote
Not if this bloody rain continues - which it looks set to all week! Evil or Very Mad
robbiej
PostPosted: Mon May 15, 2017 11:49 am    Post subject: Reply with quote
how did you fit the splitter? I have one and not sure of the best way to get it on
Goto page Previous  1, 2
Page 2 of 2
