997 : 2004- 74
996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
Pecky
PostPosted: Fri Feb 17, 2017 12:10 pm    Post subject: Strange tiptronic Reply with quote
I think ive got a ghost in my box,when in lower geras there a jump like a gear shift and the revs drop as normal but no shift then the shift hapoens and it changes up.could this just need an oil change,any ideas guys
lofi
2001 Porsche 996 Turbo
PostPosted: Fri Feb 17, 2017 2:20 pm    Post subject: Reply with quote
What's the age of the car? There are different control units for diff aged cars and it helps a little.
Would what you've described be explained as a pause between the shift happening and the torque convertor locking up, if that makes sense?
LoFi
996 turbo tip
ex 944 2.5 manual
ex 964 C4 manual
Pecky
PostPosted: Fri Feb 17, 2017 3:01 pm    Post subject: Reply with quote
Its a 99 carrera 2.its more like you set of as normal in second then revs dip and it seems just like its changed up but dash indicater still shows second,revs keep building up then a second dip in revs then change up to third,same happens from third to forth.thanks for reply
lofi
PostPosted: Sun Feb 19, 2017 1:32 pm    Post subject: Reply with quote
Ok, not sure I can be much help, but a couple of things. Does it do the same from 1st to 2nd? I ask because there is no torque convertor lock up on 2nd. Secondly, does it do it with a manual change and thirdly, does it still do it if you put the box into its most aggressive map, which is done by pumping twice quickly on the accelerator?
LoFi
996 turbo tip
ex 944 2.5 manual
ex 964 C4 manual
Reims
PostPosted: Sun Feb 19, 2017 6:46 pm    Post subject: Reply with quote
With any new faults on a tip box then checking for fault codes is the first thing , after that an oil and filter change is the cheapest way to possibly correct any problems.
At an Indy these days !
