996 : 1997-2005 46
964 : 1989-1993 6
Boxster : 1997- 13
Cayman : 2005- 17
Cayenne : 2003- 8
912-914-924-928-944-968 3
Gollom122
PostPosted: Thu Feb 16, 2017 11:09 am    Post subject: Aero kit / GT3 front splitter PU Reply with quote
I am in need of a new splitter due to speed bump scrapes and the cars having a bumper respray for the summer. The last time I purchased from OPC I paid £149 plus VAT. They now want £215.55 plus VAT (£258) which seems a lot for a piece of plastic.
So, as an alternative to an bi-annual consumable I was wondering if anyone had painted one with plasti dip before? And if so, what results did they get?
I wish I'd kept the old ones now to try this with.
If anyone knows of a cheaper source, Part number is 9975059839(last digit can be a 2,4 or 6)
Big E 118
PostPosted: Thu Feb 16, 2017 1:36 pm    Post subject: Reply with quote
Yes, I sprayed my aero kit splitter with Plastidip. Use the matt black and the finish is very close to the other bits of black plastic trim.
It's pretty hard wearing and if you do need to touch up you just spray the area you need to, it blends very easily with the older coats.
I do Euro jaunts and track days and it's easy to keep the splitter looking fresh.
For the sake of £8 a can of eBay it's worthwhile trying and seeing what you think.
Gollom122
PostPosted: Thu Feb 16, 2017 2:04 pm    Post subject: Reply with quote
Thanks for the advice,
I was thinking of overspraying the black with the glossifier to add a shine. Given your comments do you think this is necessary - I have a Red car.
Does a single can do the job? I was thinking 4 to 5 coats?
Big E 118
PostPosted: Thu Feb 16, 2017 2:22 pm    Post subject: Reply with quote
I wouldn't use the glossifier, personally I think it's a good match without.
After a good clean and panel wipe of the surface I put a light first coat then four pretty heavy coats on and it came out well.
I watched the youtube channel "dip your car" to get hints and tips on how to do it properly!
Gollom122
PostPosted: Thu Feb 16, 2017 2:24 pm    Post subject: Reply with quote
Cheers,
I'll have a go.
I can always add glossifier later if not happy with the matt finish Thumb
ollymeister
PostPosted: Fri Feb 17, 2017 12:04 pm    Post subject: Reply with quote
I too need a replacement, and have been eyeing these up for a while.
http://www.ebay.co.uk/itm/05-09-Porsche-911-997-GT3-GEN-1-3-6-Front-Aero-Lip-Splitter-OEM-Plastic-NEW-/142240465395?hash=item211e3141f3:g:ovsAAOSw~OdVYlqw
997 C2S
Z4 Coupe
Gollom122
PostPosted: Fri Feb 17, 2017 4:10 pm    Post subject: Reply with quote
They look a better option than OEM. I am going to give the plasti dip a go first.
Good spot.
Let us know quality if you buy.
Gollom122
PostPosted: Mon Feb 20, 2017 5:45 pm    Post subject: Reply with quote
Just noticed he only has one left - better move quick if you are going to take the plunge
Gollom122
PostPosted: Tue Feb 21, 2017 4:07 pm    Post subject: Reply with quote
A big thanks to BIG E 118. I never expected the Plasti Dip to do such a fantastic job - I wish I'd spent more time rubbing down before I started as I think the finish would have been perfect.
Here are the before and afters
Middle after dip
 Filesize:  23.07 KB
 Viewed:  2490 Time(s)
Middle Before
 Filesize:  29.54 KB
 Viewed:  2491 Time(s)
Side after dip
 Filesize:  23.51 KB
PostPosted: Tue Feb 21, 2017 4:56 pm    Post subject: Reply with quote
Wow thats a dam good finish did yours have any splits in as mine has a small 10mm split at the bottom right in the middle thanks to my local multi story Mad
might have to give that a go myself mmmmm rephrase might have to get someone to do this for me Grin Grin
Gollom122
PostPosted: Tue Feb 21, 2017 6:08 pm    Post subject: Reply with quote
Your body shop can 're-weld' the split. Mine was not split.
It is an easy DIY job.
Removal - pull from the middle forwards and down, then work your way to each side - there is a torx screw underneath - I never put mine back in as its not needed to hold the splitter in.
Once removed, I'd recommend a light rub with emery paper, then wipe clean with IPA or solvent cleaner. Hang from the garage roof upside down so you have good access to the bottom of the splitter. I used the screw holes and added two more holes where the splitter fixes to the bumper.
Lightly 'dust' the paint on in several coats, leaving to dry for half an hour in between coats. I ended up adding two more coats after I took these photos until the can was almost empty (7coats in total).
I paid £12 for a can and would happily do this a couple of times a year. The old dip comes off like a sheet of vinyl and can even be touched up when you get the odd scrape.
Thumb Thumb
PostPosted: Tue Feb 21, 2017 7:17 pm    Post subject: Reply with quote
thanks for the tips mate Thumb Thumb £12 has to be better than £200 for a new one Grin
Gollom122
PostPosted: Fri Feb 24, 2017 2:28 pm    Post subject: Reply with quote
Back on the car
Freshly painted bumper and my plasti dipped splitter
 Filesize:  59.44 KB
 Viewed:  2307 Time(s)
 Filesize:  60.29 KB
 Filesize:  61.71 KB
Robx
PostPosted: Fri Feb 24, 2017 5:33 pm    Post subject: Reply with quote
Looking at one of these from the states -
http://www.ebay.co.uk/itm/05-08-Porsche-911-997-GT3-Front-Bumper-Lip-Urethane-/281204299566?hash=item417915172e:g:cnsAAMXQfvlSfzt8
Plenty sold so must be OK...
Gollom122
PostPosted: Fri Feb 24, 2017 7:37 pm    Post subject: Reply with quote
looked at these a couple of years ago. Rennlist reported these as quite brittle from memory. Suggest you research there - similar price to the UK ebay ones mentioned further up in this thread.
Robx
PostPosted: Sat Feb 25, 2017 3:09 pm    Post subject: Reply with quote
Cool, brought the one mentioned earlier in thread. Will report back on quality / fitment. Cheers
A11ykf
PostPosted: Sun Feb 26, 2017 2:11 pm    Post subject: Reply with quote
Interesting. Do they really come off that easy and only have one Torx screw? Mine is badly in need of some attention. I'll need to take a look at doing it myself
PostPosted: Sun Feb 26, 2017 4:53 pm    Post subject: Reply with quote
Gollom122 wrote:
Back on the car
That looks great, must be the way I go is it just plastidip or do I need a matt clear coat on after Thumb
Big E 118
PostPosted: Sun Feb 26, 2017 6:11 pm    Post subject: Reply with quote
Looks great, glad I could help!
Gollom122
PostPosted: Mon Feb 27, 2017 3:50 pm    Post subject: Reply with quote
That's just the black plasti dip. Splitter pulls off easy - chances are if you've every had yours replaced the screws at each end won't be there. Really simple to remove.
