996 : 1997-2005 46
964 : 1989-1993 6
Boxster : 1997- 13
Cayman : 2005- 17
Cayenne : 2003- 8
912-914-924-928-944-968 3
badlands
PostPosted: Thu Feb 16, 2017 10:03 am    Post subject: 993 immobilizer/alarm problem Reply with quote
Ok the weather looks surprisingly warm so I couldn't wait any longer!! Went to the garage this morning and reconnected the battery.
With the battery now reconnected, as soon as I opened the car door all hell broke loose - alarm blaring, indicator lights flashing furiously Evil or Very Mad
I quickly put the imobilizer fob into the dash and got the 3 beeps, then turned the engine over with the key. This seemed to stop the alarm blaring, but indicators still flashing. Think the alarm soon went off again so I gave up and disconnected the battery again.
Any ideas....if I put the DME relay back in and actually start the car this evening, will all be back to normal?
Note, I don't have the imob with the buttons - it's the version which is just the door/ignition key and the little key fob.
Any advice much appreciated!
bye
current: 993 carrera coupe, manual, iris blue, bilstein pss10
ex 964 c4
ex 993 carrera cab
Endoman
PostPosted: Thu Feb 16, 2017 10:32 am    Post subject: Reply with quote
Use key to lock /unlock drivers door. Used to work when I had HP1000 fitted.
badlands
PostPosted: Thu Feb 16, 2017 12:13 pm    Post subject: Reply with quote
thanks for advice, will give that a try this evening
ex 964 c4
ex 993 carrera cab
