997 : 2004- 68
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Classic : 1950-1965 1
Boxster : 1997- 15
Cayenne : 2003- 9
912-914-924-928-944-968 4
Starwr1973
PostPosted: Wed Feb 15, 2017 3:01 pm    Post subject: Advice needed..... Reply with quote
Hi guys im looking for some standard front shocks and shock mounts and coil springs for my 2002 996 carrera 4 cabriolet.
Im not looking for M030 sports i just want to keep it standard and was just looking for some advice on where to get them other than from opc? Does anybody happen to know the oem part numbers?
Thanks any info and advice wil be appreciated....
Halcyon
PostPosted: Wed Feb 15, 2017 3:14 pm    Post subject: Reply with quote
I think Bilstein B4 is the standard shock, search eBay for prices (about £240 each from memory?)
996.2 Carrera 4 Convertible Tip
crash7
PostPosted: Wed Feb 15, 2017 4:27 pm    Post subject: Reply with quote
Euro Car parts sell them, the price is eye watering! - You would need to be committed to the cause.
http://www.eurocarparts.com/shock-absorber
If you wish to maintain your standard setup have you considered having your current dampers refurbished?
Marky911
PostPosted: Wed Feb 15, 2017 5:17 pm    Post subject: Reply with quote
Hi Star,
I know you want to keep it standard but the M030 is still a genuine factory option so not viewed as detrimental in any way. It also is only a very conservative drop in height, in most cases slightly disappointing for people who want a noticeable drop, so it will look and feel very standard.
There's a 39k mile set for sale in the classifieds on here for £250. If your car has covered a lot more miles than those I'd give them a lick of paint and stick them on. Or you can buy the full kit including anti roll bars for £1000 from main dealer.
Only thing I'm not 100% on is if the cabriolet has different spring rates for the extra weight. Can't see it affecting anything as the extra weight is only that of a passenger or some luggage.
Failing that it's off to the main dealers for your standard stuff.
Starwr1973
PostPosted: Wed Feb 15, 2017 6:35 pm    Post subject: Reply with quote
Thanks guys and im not sure if the spring rates are diffrent
shaunpr
2002 Porsche 996 Carrera 4
PostPosted: Thu Feb 16, 2017 1:15 am    Post subject: Reply with quote
Hi
Just had to refresh my suspension on my C4 cab due to a broken spring.
Mine is lowered with H&R springs so needed to replace with the same and they are only available in a complete set.
I got mine from ECP after talking to the branch got them for £279.00 inc vat. They had them the following morning for me to pick up.
If you are doing this yourself you will need a impact wrench and 16mm socket and a set of coil spring compressors.
As you mentioned you will need top mounts & bearings. I did bump stops at the same time.
Happy to give you my insight on doing the fronts if interested. Also got a set of brand new front pair b4 for what they cost me...£324+shipping. Found I did not need them once I stripped the front down.
Picture shows ride height with H & R fitted
 Filesize:  420.99 KB
 Viewed:  739 Time(s)
X51 996
PostPosted: Thu Feb 16, 2017 11:32 am    Post subject: Reply with quote
Might be worth speaking to Bilstein UK as they can rebuild dampers for around £80+VAT from memory.
2003 911 Carrera 2 coupé, Arctic Silver - 3.6 manual, X51 Carrera PowerKit, X74 Suspension, Sunroof delete, PSM delete. Black leather crested sports seats (XSC), XAG rear spoiler, 5-spoke 18" Carrera Alloys, Xenons.
2004 Mercedes E55K AMG Estate
1988 Mercedes 190E 2.3-16
1988 Mercedes 190E 2.5-16
