Posted: Fri Feb 10, 2017 8:41 pm Post subject: Head light damage
I had the headlights off today to give them a mop, On removal I could hear something rattling about internally, turns out to be a bit white plastic, I assume this has something to do with beam angle etc, the small white plastic part is held in with a screw but I've not been able to source a replacement.
Has anyone come across this before or if it's possible to get parts for the headlights.
maldren Hockenheim
Posted: Sat Feb 11, 2017 9:14 am Post subject:
Can you post a pic? _________________ Mike
Locosaki Monza
Posted: Thu Feb 16, 2017 10:06 pm Post subject:
My driver side headlight is the same, the part is what hold the inner light set up to the black plastic housing, I've not come across a part number yet.
I unscrewed the pin connector and got the broken part out from there, just leaves enough room to get in with a torx bit _________________ Carrera 4 MY99 with full Hartech rebuild
Drew1209 Silverstone
Posted: Tue Feb 21, 2017 1:12 pm Post subject:
I've attached a picture of the part I was referring to.
From the inner head light.
Filesize:
647.52 KB
Viewed:
776 Time(s)
