996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
jlee
PostPosted: Sat Feb 04, 2017 11:01 am    Post subject: catalytic convertor backbox c2 (will c4 backbox fit a c2?) Reply with quote
Folks,
i have a 1991 c2 and wondered if the catalytic converter is the same for the C2 as the C4 (ie. is it interchangeable between these 2 cars)
have a c4 catalyctic converter (used) and need to replace mine which is a c2.
thanks
ras62
PostPosted: Sun Feb 05, 2017 10:37 am    Post subject: Reply with quote
C2 and C4 use the same exhaust system but the two boxes are simple silencers, the cat is installed before the first box just after where the two manifolds join. In the UK a 1991 doesn't legally need a catalytic converter so many opt for a bypass to get more noise and power.
