I've got a problem with the drivers side window when the door is opened.
When the door is opened from the outside, the window drops but goes back up while the door is open so i can't shut it. Am having to lower the window from the switch after putting the key in the ignition
It's fine from the inside and the window stays dropped until the door is closed and it goes back up correctly :dont know:
..Anyone seen similar issues?
