996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Clanky
2007 Porsche 997 Turbo
PostPosted: Sat Feb 04, 2017 5:00 pm    Post subject: Reply with quote
Looks good!
& very interested in the fix you came up with for the horn.
If it saves me having to splash out on a new control unit I'm interested!
Hope you get the details up soon!
996 C4s (Gone)
997 Turbo
S3 Daily Driver
kam
PostPosted: Sat Feb 04, 2017 5:43 pm    Post subject: Reply with quote
Clanky wrote:
Looks good!
Thanks!
Pm you my mobile, maybe easier to explain.
997 Turbo manual GT silver
996 C4s
Clanky
PostPosted: Wed Feb 08, 2017 9:11 pm    Post subject: Reply with quote
Well Kam, thanks for the info. I took some tie out today & managed to get my horn working with the Gen.2 wheel now.
As per your info. I was also able to carry out a minor addition to the procedure myself.
I discovered that the orange multi plug has a small pink plastic clip inside it (see pic) which passes through the centre & holds all of the pins in place.
If you pop it out, you can remove the two pins & swap them round, allowing you to use the original spade connector as an earth to the airbag chassis.
Afterwards, I was able to simply splice the steering wheel ground to the original wire by soldering & a small piece of heat shrink & re-assemble the connector so it looks pretty much stock.
Note: I'm not sure if this would work as easily with a M/F wheel, as it's likely the second earth wire from the original spade connector connects to the M/F controls inside the wheel, but it does work fine with the plain wheel.
996 C4s (Gone)
997 Turbo
S3 Daily Driver
 Filesize:  127.24 KB
 Viewed:  1165 Time(s)
 Filesize:  104.12 KB
kam
PostPosted: Wed Feb 08, 2017 9:30 pm    Post subject: Reply with quote
Great news! Glad it's working thumbsup
May even swap mine around and connect the original wire.
996 C4s
160dmb
PostPosted: Mon Feb 04, 2019 9:37 pm    Post subject: 997 Heated seat retrofit - Non OEM Reply with quote
Research on here seems to suggest that converting my recently acquired sports seats to heated using OEM Porsche parts is a rather forlorn hope.
Has anyone acheived a similar outcome using non OEM seat heaters and how and what did you use?
I would much rather make everything look standard if possible but as I have luxury of two pairs of seats right now I can work on converting the sports seats whilst the comfort ones are fitted.
Thanks in advance
David
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Mon Feb 04, 2019 9:42 pm    Post subject: Reply with quote
calling Kam, who has done this on his 911 Turbo
let me merge this topic with his thread
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON FACEBOOK
DucatiRob
PostPosted: Tue Feb 05, 2019 8:58 pm    Post subject: Reply with quote
Looks great, on my ever growing mod list! Like the yellow band too Thumb
Mercedes CLK DD
Ducati 996
kam
PostPosted: Tue Feb 05, 2019 9:06 pm    Post subject: Reply with quote
Cool
996 C4s
kam
thumbsup
996 C4s
Cunno
PostPosted: Wed Feb 06, 2019 9:51 am    Post subject: Reply with quote
kam wrote:
Had to fit resistors for the seat air bags.
Can you supply more details? What was done where did you get the kit from please?
Porsche is for driving not for washing.
Present Car: 2006 3.6 Porsche GT3 997(White)
Ex: 2006 3.4 Porsche Cayman S (Silver)
Ex: 2001 2.7 Porsche Boxster (Seal Grey)
kam
PostPosted: Wed Feb 06, 2019 9:57 am    Post subject: Reply with quote
Hi
See link below, fitted these to the Airbag plug. No warning light issues...
https://www.ebay.co.uk/itm/PORSCHE-2-7-OHMS-OHM-SRS-AIRBAG-RESISTORS-0-25W-2-AMP-FUSED-DELETE-FAULT-LIGHT/261532742948?hash=item3ce490f524:g:crAAAOSwfVpYnzVc:rk:1:pf:0
996 C4s
kam
PostPosted: Wed Feb 06, 2019 10:19 am    Post subject: Reply with quote
After a few months, I had the seat bases and backs covered in "Real" Grey Alcantara.
Also the Gear Gaiter, centre glove box cover. All matches the steering wheel...
Same colour as OEM Porsche....
996 C4s
Mezgerite
PostPosted: Wed Feb 06, 2019 1:59 pm    Post subject: Reply with quote
Looks great.
How do you get on with putting suitcases etc in the back? Do they squeeze through when fully forward?
kam
PostPosted: Wed Feb 06, 2019 2:13 pm    Post subject: Reply with quote
Mezgerite wrote:
Looks great.
Hi
Don't use the rear seats!, have a couple of other cars to use.
Not a daily driver, keep it indoors for nice sunny days
Very Happy
Thank you...
996 C4s
MaxA
PostPosted: Wed Feb 06, 2019 2:50 pm    Post subject: Reply with quote
I like the seats. I think I'd just pull out the rear seat bases and belts as well. And then likely add a cage and harnesses. But then I'd be getting carried away...
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
kam
PostPosted: Wed Feb 06, 2019 2:52 pm    Post subject: Reply with quote
I agree, that's why I stopped!...
Thank you, they are really comfortable due to adding more foam in the base and rears.
996 C4s
kam
PostPosted: Thu Feb 07, 2019 2:11 pm    Post subject: Reply with quote
Thank you!, does look great in yellow thumbsup
996 C4s
Mezgerite
PostPosted: Thu Feb 07, 2019 4:58 pm    Post subject: Reply with quote
kam wrote:
Mezgerite wrote:
Looks great.
Hi
Very Happy
Thank you...
Mine is very much a sunny day car, but it does road trips so need to pack it!
Is the Porsche alcantara black or grey?
kam
PostPosted: Thu Feb 07, 2019 5:03 pm    Post subject: Reply with quote
Mezgerite wrote:
kam wrote:
Mezgerite wrote:
Looks great.
Hi
Very Happy
Thank you...
Hi
It is a nice dark grey, really spot on to the OEM steering wheel....
996 C4s
Cunno
PostPosted: Thu Feb 07, 2019 5:52 pm    Post subject: Reply with quote
kam wrote:
Hi
Thanks for the link, do they come with installation instructions?
Page 2 of 3
