996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Macan : 2014- 3
veearrsix
PostPosted: Thu Jan 26, 2017 7:14 am    Post subject: Early Cayenne S bore scoring Reply with quote
Hi All,
I have purchased a 2003 Cayenne S on a popular auction site. I've done a bit of reading about potential issues and the only one that I want to ask more about is the potential bore scoring problems. It is a high mileage engine, so I guess its susceptible to this problem.
I'd like to know if the engine issue is the same sort of thing as the 996 engine issues, where, yes there are some issues but it's a small percentage of engines that might be affected. I had A C4S previously and never had a problem. Or is the issue with the early V8's a dead cert to happen?
cheers in advance
996T Tip - Polar Silver
Ex: Carrera 4S manual - Basalt Black
Demort
Estoril
PostPosted: Thu Jan 26, 2017 7:35 pm    Post subject: Reply with quote
Its a small percentage of cars that suffer from it from what ive seen , well , so far at least as they are getting older .
the give away is removeing and inspecting the spark plugs ( oil fouling ) or a certain knocking from the engine when warm and at idle .
Seems to be more common on bank 2 in my experience so a plug check that side might help prove or disprove it for you .
I believe its to do with a blocked spray jet on certain cyls .. but i would think Hartech could answer that question far better than i could .
At an Indy these days !
