Re: 1990 964 manual C2 cold start problem.
peter y.s pang
27 Aug 2012
75
Hi everybody. The 964 seldom use it. Everytime it need several times to crank it, the engine can willing to run. when i turn the key, i can hear the starter try to turn the flywheel, but the engine did not want to run, but after 10 - 15 times crank. the engine start run and it will run smoothly. If the engine get warm. i can start the car no problem. The battery have 12.4 V , seems health. Any idea what kind of problem ?
Peter,
It looks as though your starter motor is on the way out.
I had the same problem with my 1990 C2. You can get a a service exchange, new for old.
Cheers,
Paul
Peter,
2 further things to check, I believe there's a cable going from the solenoid to the starter, I've read of people having issues with this cable where it's almost frayed apart which would cause bad conductivity, also there's an earth cable from the engine to the body which can also cause poor starting if the contact area needs taken apart and cleaned with sandpaper or a wire brush.
It probably is your starter as Paul said but better to check the cheaper fix options first in case your problem lies there.
Logan
124,559
1,441,517
48,973
mkrt1972
