997 : 2004- 60
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 20
Cayenne : 2003- 7
New997buyer
Banned
PostPosted: Fri Jan 27, 2017 7:18 pm    Post subject: Reply with quote
GT4 wrote:
New997buyer wrote:
Re the Bluetooth widget - now I've seen the neatness of your one mine could end up in the wife's Polo..... Scratch Chin
Re the rest cheers and appreciated Thumb
BTW are you Dinslakening in it? Question
Dinslaken/Harrow(?), what's few thousand k's between friends Floor
Have you a nice Durametric cable too?
Happy to show you mine!
Seriously though, I can just post firmware discs - but you may be upto date for 2016 DVD.
You need to PM to advise your PCM and DVD firware vers Thumb
Cheers! PM okay at this 'tender' stage Embarassed
But the Dinslaken question is a genuine one. Will you be taking it over for the show etc? Question
GT4
Nordschleife
Nordschleife
PostPosted: Tue Jan 31, 2017 2:22 pm    Post subject: Reply with quote
Another little one
Boot carpet screw (previously MIA)
Just waiting to see if weather improves enough this weekend for LTT fit or PU removal.
 Filesize:  664.11 KB
 Viewed:  4319 Time(s)
 Filesize:  626.02 KB
GT4
Nordschleife
Nordschleife
PostPosted: Sat Feb 04, 2017 3:19 pm    Post subject: Reply with quote
OK, so probably the biggest (or second biggest mod I was planning), but still doable in 2 hours first time.
No such thing as third-time lucky, as the hose retainer had corroded and after struggling to even turn it around for 20 mins, it was apparent one off the twin bands had snapped. This meant as much as I squeezed the release tabs, the snapped ring never opened (released), so I had to angle grind.
But that was the only gremlin, in fact this was the "driest" change I'd done and I think I lost less than cup of coolant in total (main reasons were unscrew the drain plug over the bucket Confused , and use the reservoir cap up top to control the flow rate - also, to stop the block dripping on me continuously once "drained" in some sort of water-torture - I simply lightly screwed the drain plug back in whilst I continued lying under the car)
I'm rambling, because basically, the method is here:
http://911uk.com/viewtopic.php?t=83808
and
http://911uk.com/viewtopic.php?t=65932
Only real difference between 997 and 996 was the E10 Torx (rather than hex bolts) and "quick" release hose retaining clip (rather than Jubilee)
Oh, and for the 996 I used an insert only (£80 from Hartech) and gasket from OPC (I think £4.50) now I can get a full housing, gasket and insert by Wahler (but housing actually Porsche part) from https://www.frazerpart.com/ for £45
The part is the same for any M96/M97 (ie 996.1 3.4 all the way through 997.1 3.Cool
Note: the Porsche part number has been removed by Wahler (as no one but Porsche can sell OEM parts). But note the official "triangle P" OEM part stamp Floor
Photo list:
1.) BorgWarner Box (Wahler)
2.) Housing and 71 deg tstat
3.) Part number redaction (but \P/ stamp)
4.) Gasket
5.) Chock
6.) Raised rear by (the higher the better for air-lock mitigation on re-commissioning) - I drove up onto a sleeper and then jacked for a 55cm lift in total)
7.) ... and front view
8.) WD-40'd hardline and housing bolts (and the recalcitrant hose clip)
9.) Draining (and the drain plug on the socket)
10.) Pink!
 Filesize:  304.93 KB
 Viewed:  4238 Time(s)
 Filesize:  343.21 KB
 Filesize:  503.46 KB
 Filesize:  475.18 KB
 Viewed:  4240 Time(s)
 Filesize:  470.58 KB
 Filesize:  768.6 KB
 Filesize:  208.64 KB
 Filesize:  384.47 KB
 Filesize:  414.02 KB
 Filesize:  236.73 KB
GT4
Nordschleife
Nordschleife
PostPosted: Sat Feb 04, 2017 3:29 pm    Post subject: Reply with quote
Cont'd
11) Old vs New
12) The angle-ground clip and the Jubilee replacement (£1.79 Halfords)
13) Block mating face (pre clean)
14) ... and cleaned (wet and dry)
15) Housing on
16) All back together
17) Oil temp seems to be stable at 85-87 deg-ish (and oil pressure about 0.2-0.3 bar higher)
 Filesize:  402.65 KB
 Viewed:  4213 Time(s)
 Filesize:  448.7 KB
 Filesize:  340.02 KB
 Filesize:  487 KB
 Filesize:  298.13 KB
 Filesize:  411.53 KB
 Filesize:  311.08 KB
New997buyer
Banned
PostPosted: Sat Feb 04, 2017 4:45 pm    Post subject: Reply with quote
Great work Paul thumbsup
Sorry if I missed it but how long did it take you start to finish? Question
GT4
Nordschleife
Nordschleife
PostPosted: Sat Feb 04, 2017 6:02 pm    Post subject: Reply with quote
About two hours, but all three LTTs have been staccato due to documenting (I kept having to get up and take photo - took about 60 in total, then put phone back out of harms reach so I didn't sit on it, kick it or cover with WD-40 or coolant!) - I had hoped to beat my previous time.
There was faff with the sleeper "ramps" and a good 20 mins wasted on the "quick release" hose clip - a good old fashioned jubilee clip would have been off in seconds!
I wasn't in a rush, I could visualise what needed doing, the sun was out and the music was on.
I suppose all going to plan, you could do in an hour.
There really aren't many stages (a drain plug, a hose clip and seven bolts)
I think I went out for a drive* afterwards for longer, but that took in OPC Hatfield and free food and drink and 991 brochures.
*I stopped every 5 miles or so to check the coolant level (continually monitoring oil, coolant and heater performances in the meantime) and refill.
Filled the remaining 2L over 40 miles.
I checked again this am and went for quick 15 mile drive this am (purge valve down) but taking 1L to Kent tomorrow, just in case.
New997buyer
Banned
PostPosted: Sat Feb 04, 2017 6:43 pm    Post subject: Reply with quote
Great work thumbsup
askgeez
PostPosted: Sat Feb 04, 2017 7:04 pm    Post subject: Reply with quote
GT4 wrote:
..... taking 1L to Kent tomorrow......
You coming for breakfast at Da Mount?? Dont know
997.2 GT3 coupe Manual (03/19 >)
911 SC Targa Manual (04/19 >)
996.2 C4s Cabriolet Manual (09/19>)
Gone:
997.2 GTS coupe PDK (06/17-02/19)
997.1 C4s coupe Manual (04/15-06/17)
GT4
Nordschleife
Nordschleife
PostPosted: Sat Feb 04, 2017 7:35 pm    Post subject: Reply with quote
Erm Question
Just before you, apparently!
 Filesize:  74.81 KB
 Viewed:  4128 Time(s)
PostPosted: Sat Feb 04, 2017 8:19 pm    Post subject: Reply with quote
Loving your photoshop skills making the car look dirty.
askgeez
PostPosted: Sat Feb 04, 2017 8:43 pm    Post subject: Reply with quote
GT4 wrote:
Erm Question
I'll get a hang of this forum malarkey one of these days !
Looking forward to seeing the new car !
Gone:
GT4
Nordschleife
Nordschleife
PostPosted: Sat Feb 04, 2017 8:44 pm    Post subject: Reply with quote
No Photoshop
It's a Rat Wrap
PostPosted: Sat Feb 04, 2017 8:48 pm    Post subject: Reply with quote
Scat wrap!
GT4
Nordschleife
Nordschleife
PostPosted: Sat Feb 04, 2017 9:59 pm    Post subject: Reply with quote
Shlt man, you all up in my grille!
GT4
Nordschleife
Nordschleife
PostPosted: Sun Feb 05, 2017 9:55 pm    Post subject: Reply with quote
LTT seems fine.
70 miles at 79mph (M25 @ 7-8am Sunday morning) giving just under 90 deg C on oil temp and an average speed over the same distance of 31.4 MPG.
 Filesize:  309.62 KB
 Viewed:  3991 Time(s)
seeforez
PostPosted: Sun Feb 05, 2017 10:28 pm    Post subject: Reply with quote
how the heck do you get over 30mpg in a 911, do you roll down hills and only go up them if there's a good wind behind?
GT4
Nordschleife
Nordschleife
PostPosted: Sun Feb 05, 2017 10:54 pm    Post subject: Reply with quote
1) get a small engined one
2) fit LTT for better economy, not blended optimised emissions
3) drive with no traffic
4) as above, and let CC keep speed consistent
5) drive on a warm, low pressure (low air density) day*
*I guess I'll just have to try again in August
Dont know
seeforez
PostPosted: Mon Feb 06, 2017 1:33 pm    Post subject: Reply with quote
i'll keep an eye out for a 911 stuck at 55 on cruise control with all the lorries overtaking
GT4
Nordschleife
Nordschleife
PostPosted: Mon Feb 06, 2017 1:48 pm    Post subject: Reply with quote
That would probably clear 40mpg!
I meant I would try the experiment again under different temp (weather) conditions, I wasn't planning on changing more than one factor at a time.
#4 = 79mph
PostPosted: Mon Feb 06, 2017 3:25 pm    Post subject: Reply with quote
GT4 wrote:
No Photoshop. It's a Rat Wrap
Very effective it is too. It makes the car look stunningly filthy.
Having the number plates and wheels done really completed 'the look'. Thumb
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Page 6 of 9
