New plugs... any difference?
Robertb
Yas Marina
1 Sep 2003
8,406
I've treated my daily, an 04 3.0 petrol X5 to an inspection 2 service, inc new filters and spark plugs.
Feels quite different... more power.
Is it a placebo effect, or can new plugs and bits make a difference?
I've always imagined that as long as a plug was sparking OK, then a spark was a spark on the basis all it had to do was ignite the fuel mix.
1. Engine has a rough idle
Your engine idles when it is a stationary and in this position the engine normally produces around 1000rpm. The sound the engine gives off is constant and smooth but if your spark plugs aren't performing as they should, your engine will produce a rough and jittery sound while producing larger vibrations through the car. Not having this checked can lead to costly damage being done.
2. Having trouble starting your car?
Many people put their car not starting down to being out of fuel or having a flat battery. One possibility you may overlook is having bad or worn spark plugs. If your spark plugs don't produce the spark needed to get the vehicle moving, then you're going nowhere. It is also possible that faulty spark plugs are causing your battery to drain. If so you need to have your battery and spark plugs changed as soon as possible.
3. Your engine misfires
When your engine misfires it causes the vehicle to halt for a fraction of a second and then continues it's usual movement. This means the vehicle isn't functioning as smoothly as it should because one or more cylinders aren't firing properly, which can also lead to higher amounts of emissions.
4. Engine surging
When a vehicle sucks in more air than usual in the combustion process it can cause the vehicle to jerk and then slow down or continually start and stop, which means the vehicles engine is working inefficiently. This is also known as engine hesitation and dangerous situation can arise if this occurs in traffic.
5. High fuel consumption
If your spark plugs have deteriorated you'll notice that your vehicles fuel economy can decrease by up to 30% due to incomplete combustion. If you notice you're having to fill up more often than usual it can be caused by deteriorating spark plugs. To get back to your vehicle's optimum level of fuel consumption all you'll need to do is have your spark plugs changed.
6. Lack of acceleration
If your vehicle is accelerating poorly it is fairly easy to tell. It feels as if the vehicle doesn't want to respond when you put your foot down, or it does but not instantly as you've become accustomed to. It can also feel as if your vehicle is trying really hard to pull itself along. This 'sluggishness' can be easily fixed by having the vehicle serviced with a spark plug change.
Cheers... seems it could make a marginal difference at best... the new air filter element may also help get more, umm, air in, so it's breathing better too.
I suppose marginal gains added up may contribute something.
124,598
1,441,971
49,033
drthein
