997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
Armagreggon85
PostPosted: Fri Jan 06, 2017 11:48 am    Post subject: Wanted 996 Stomski Manifold Jig Reply with quote
Hi
I'm undertaking the dreaded manifold bolt replacement on my 996 and in need of a Stomski jig. Willing to buy/rent/borrow one if anyone has one available.
Greg
Delanor
PostPosted: Sun Jan 08, 2017 7:15 pm    Post subject: Reply with quote
To be honest the Stomski jig is designed to be used over and over, if your DIY skills are good then buy yourself an exhaust gasket and use it as a template to make your own jig out of a sufficent aluminium plate if you are using it once then hardened bushes would not be needed as the correct sized holes in your jig would act as pilots although they would have to be accurately drilled on a bench drill etc.
Del.
The forward thinking traditionalist!
Current - 210 bhp TDCI Ford Kuga 4x4 Sport
Current - Crystal White 40th Anniversary RX-8.
Current - Porsche Carrera Cabriolet in Viola.
